mellomade 141 Posted May 28, 2020 Posted May 28, 2020 Hi All, Long time - I hope everybody is doing well in these crazy times. I ran into an issue with the latest stable where the resume percentage settings are missing from the Playback tab in the user settings. Bug or feature? If feature - is there a new place to set these? Thanks! -J
Solution Happy2Play 9802 Posted May 28, 2020 Solution Posted May 28, 2020 That setting is a per library setting now. Dashboard-Library-Select each library-enable Show advances setting-Scroll all the way to the bottom 1
mellomade 141 Posted May 28, 2020 Author Posted May 28, 2020 Nice one! Thanks @@Happy2Play! I knew I was missing something. This is what happens when I don't need to mess with Emby for over a year - kudos though guys - it's really great when things just work for so long that you forget.
