Carlo 4561 Posted July 9, 2020 Posted July 9, 2020 4 hours ago, Luke said: @cayars what is the issue here? The issue is that it's not using the folder name but the filename. For example from this thread: /Eternal Sunshine of the Spotless Mind (2004)/vgmn.mkv does not match using the folder name. /Eternal Sunshine of the Spotless Mind (2004)/Eternal Sunshine of the Spotless Mind (2004).mkv will match perfectly. Both have the same subdirectory name but only the movie name is different. Same thing with movie 7500 or any other. It seems that the folder is not being used but still requires the filename to be correct. That is what I pinged you about. Carlo
