Luke 42289 Posted October 3, 2020 Posted October 3, 2020 On 9/28/2020 at 11:48 PM, bakes82 said: The UI is different, its setup for a mobile format, where shield is not considered a mobile device. Every thing is just way bigger looks weird and Ive only been testing it for like 2hr so I noticed a diff right away. Here logs, Im not admin of this server, just testing emby out if you need server logs will be a day until mine gets spun up. old ui new ui 741ac94c-c550-4e77-9af0-5094dda5135a.log 18.88 kB · 1 download 1de0135b-226a-4590-9fd4-1796541bbc57.log 115.12 kB · 2 downloads @bakes82 why do you feel that it's setup for a mobile format?
bakes82 167 Posted October 3, 2020 Posted October 3, 2020 My guess is because things look massive, especially on a 75" 4k screen, things can be side by side. I also didnt change anything so if it was in mobile format thats not correct for a shield and could be a reason
Carlo 4561 Posted October 4, 2020 Posted October 4, 2020 What mode do you have it set for @bakes82? Have you tried changing it to TV Mode in the options?
bakes82 167 Posted October 4, 2020 Posted October 4, 2020 I’m not running it. It’s not officially supported on the shield. Once it’s pushed out to the shield via the store I’ll look at it again.
Carlo 4561 Posted October 4, 2020 Posted October 4, 2020 It's officially supported on the Shield. It's just in testing is all. It can co-exist with the normal ATV app and doesn't interfere with that app at all. So you can use it to test with or to look at how it's doing things but then switch back to "old reliable" for normal use.
DarKni8 41 Posted January 28, 2022 Posted January 28, 2022 This issue is still persistent i think we need an unlimited butrate option
Luke 42289 Posted January 28, 2022 Posted January 28, 2022 50 minutes ago, Raajul said: This issue is still persistent i think we need an unlimited butrate option Just pick the highest one and that accomplishes the same thing.
