craigdabbs 0 Posted May 27, 2020 Posted May 27, 2020 (edited) Hi there, After rebuilding my server and spinning up a new vm for emby im coming across a weird issue with write access. I was trying to change my metadata folder to a separate drive. I made the folders, made emby the owner of folder. drwxr-xr-x 2 emby users 4096 May 27 19:35 emby-test-dir when i try and change the metadata folder to this folder, which is now on the OS drive to rule out a mounting issue. It tells me "Emby Server requires write access to this folder. Please ensure write access and try again" I run "sudo -u emby touch test" this creates a file fine with the file owner being emby. ive checked the systemd file to make sure its using emby as a user too. Also when i check the install folder in /var/lib it shows the folder like this. lrwxrwxrwx 1 root root 12 May 25 11:07 emby -> private/emby and my laptop which had emby on for a long time is not looking like this. edit:(just looked on my laptop again, its the same folder layout so all ok there.) edit: tried using acl and setting 777 on folder with same outcome on 2 different systems. Hope someone can help me, dont usually have these issues installing emby. Many Thanks Craig Edited May 27, 2020 by craigdabbs
Luke 42246 Posted May 27, 2020 Posted May 27, 2020 Hi there, have you checked out our file permissions guide? https://emby.media/community/index.php?/topic/32218-file-permissions-guide-for-new-linux-users/
craigdabbs 0 Posted May 27, 2020 Author Posted May 27, 2020 (edited) Yea i had a read through that, it can scan all my media fine. I just cant get it to write to a single folder other than its /var/lib/emby folder I think i will run up ubuntu and check on there. Edited May 27, 2020 by craigdabbs
mastrmind11 722 Posted May 27, 2020 Posted May 27, 2020 Yea i had a read through that, it can scan all my media fine. I just cant get it to write to a single folder other than its /var/lib/emby folder I think i will run up ubuntu and check on there. Is this a subfolder of something? who owns the parent?
craigdabbs 0 Posted May 27, 2020 Author Posted May 27, 2020 Initially i tried it under /media where i mount my drives. Owned by root. Then created a folder on the root drive and made the owner emby, made no difference. i cant seem to find anything in the logs either about the access attempt.
craigdabbs 0 Posted May 28, 2020 Author Posted May 28, 2020 ive installed ubunto on another vm and done exactly the same steps as on both arch systems. It works perfectly with ubuntu, im at a bit of a loss now :s.
mastrmind11 722 Posted May 28, 2020 Posted May 28, 2020 ive installed ubunto on another vm and done exactly the same steps as on both arch systems. It works perfectly with ubuntu, im at a bit of a loss now :s. sounds like ubuntu it is. enjoy
craigdabbs 0 Posted May 28, 2020 Author Posted May 28, 2020 Im a dope, should of gone to https://wiki.archlinux.org/index.php/Emby You have to edit the systemd file for external write access. Sorry.
