chudak 24 Posted May 27, 2020 Posted May 27, 2020 I am considering to get a Synology box and wonder if this forum has any do's and dont's in particular for Synology DS120j option? Main point of consideration - compatibility with Emby server. Thx
FrostByte 5454 Posted May 27, 2020 Posted May 27, 2020 Will you be playing any 4K movies or do any transcoding? If so, then I wouldn't. You should be looking at something with an Intel processor if so.
mengoshmink 16 Posted May 27, 2020 Posted May 27, 2020 Hi Chudak, Have you tried using this: https://www.synology.com/en-global/support/nas_selector When I was selecting mine I found YouTube videos mentioned suitability for/against different models for transcoding. Personally I feel a NAS is like any other hardware investment, you get back reliability with sound investment. Good luck! :-) 1
chudak 24 Posted May 27, 2020 Author Posted May 27, 2020 Will you be playing any 4K movies or do any transcoding? If so, then I wouldn't. You should be looking at something with an Intel processor if so. I don't plan on streaming 4K Do you have a recommendation for a box with an Intel processor ?
chudak 24 Posted May 27, 2020 Author Posted May 27, 2020 Hi Chudak, Have you tried using this: https://www.synology.com/en-global/support/nas_selector When I was selecting mine I found YouTube videos mentioned suitability for/against different models for transcoding. Personally I feel a NAS is like any other hardware investment, you get back reliability with sound investment. Good luck! :-) Thx What have you ended up buying ?
mengoshmink 16 Posted May 27, 2020 Posted May 27, 2020 Thx What have you ended up buying ? I ended up buying a DS918+ but at the moment it just does file sharing. I do my server stuff off a separate "server": https://uk.pcpartpicker.com/list/bdyGGG I hope these help too: https://www.youtube.com/channel/UC1z5-j4y3rFK8BqHfwToQ-w https://www.youtube.com/channel/UCFyP17HoU-vpxhIpGXnXx2g 1
Solution FrostByte 5454 Posted May 27, 2020 Solution Posted May 27, 2020 Here is a list of Synology NAS with their processors. At a minimum I would recommend getting the best one with an Intel processor you can afford. If you don't have 4K the combination of va-api and the Intel processor should be enough for your transcoding needs https://www.synology.com/en-uk/knowledgebase/DSM/tutorial/Compatibility_Peripherals/What_kind_of_CPU_does_my_NAS_have 1
