Chalklands 27 Posted May 27, 2020 Posted May 27, 2020 Not sure this is the correct part of the forum to ask this. On my homepage on my laptop on the 'My Media' section, a multiple image picture is showing for movies and music but for some reason only a single picture for TV Shows. How do I get 'TV Shows' to show a multi image picture? I have more than one TV show in my library. Thanks
Solution rbjtech 5337 Posted May 27, 2020 Solution Posted May 27, 2020 Try deleting the primary Image, use the ... on the Image itelf > edit Images and simply delete the image. It should re-create itself (with 4 bar images) with a refresh. 1
