scb99 246 Posted October 27, 2020 Author Posted October 27, 2020 (edited) Installed fine, and no problems so far. I'll double check a few more things later in case the new OS interferes with anything but so far so good PS - Thanks!!!! Edited October 27, 2020 by scb99
scb99 246 Posted October 28, 2020 Author Posted October 28, 2020 Library creation, transcoding, and remote access all seem good. Looking very solid so far.
robertxgonzalez 6 Posted October 28, 2020 Posted October 28, 2020 Luke, read the threads. Glad you guys are on it. Will wait for the final version. Regards. Robert
traderman 4 Posted October 29, 2020 Posted October 29, 2020 (edited) On 10/26/2020 at 7:27 PM, Luke said: OS5 builds ready for testing. then just follow the instructions on the website: https://emby.media/download Hi Luke, for My Cloud EX2 Ultra (OS5), what i have to download? not the BETA version..right? thank you very much Edited October 29, 2020 by traderman
Luke 42237 Posted October 29, 2020 Posted October 29, 2020 5 hours ago, traderman said: Hi Luke, for My Cloud EX2 Ultra (OS5), what i have to download? not the BETA version..right? thank you very much Yes the beta version. The OS 5 package is only in testing right now.
traderman 4 Posted October 29, 2020 Posted October 29, 2020 (edited) @Luke When i try to install the beta version i get this error. How can i resolve it? Device is connected to the network, even did a couple reboots. More importantly other applications install (PLEX, Twonky) Edited October 30, 2020 by traderman
swandruski 12 Posted October 30, 2020 Posted October 30, 2020 I'm getting that same "incomplete download error with both the beta and the stable version. I was also able to install other software, though Emby was the only one I had to do manually. Please help!
Aurel71 0 Posted October 31, 2020 Posted October 31, 2020 (edited) EMBY Beta EX2Ultra OS5: emby-server-western_digital_ex2_ultra_os5_4.6.0.3_arm.bin source: https://github.com/MediaBrowser/Emby.Releases/releases/tag/4.6.0.3 Edited November 1, 2020 by Aurel71
traderman 4 Posted October 31, 2020 Posted October 31, 2020 2 hours ago, Aurel71 said: EMBY Beta EX2Ultra OS5: emby-server-western_digital_ex2_ultra_4.6.0.3_arm.bin source: https://github.com/MediaBrowser/Emby.Releases/releases/tag/4.6.0.3 DOCKER EX2Ultra OS5: docker-19.03.8-OS5.zip sorry for the question..but what should you understand from your post? I have already tried the 4.6.03. version ... and it doesn't work..docker I don't know what it is and in the Emby forum for the installation on EX2Ultra it is not mentioned I kindly ask you to explain better thank you very much
Aurel71 0 Posted November 1, 2020 Posted November 1, 2020 (edited) links error, try instead: emby-server-western_digital_ex2_ultra_os5_4.6.0.3_arm.bin Edited November 1, 2020 by Aurel71
Luke 42237 Posted November 6, 2020 Posted November 6, 2020 New location for OS 5 builds: I haven't had a chance to update the website yet, so just find the .bin file for your model here: https://github.com/MediaBrowser/Emby.Releases/releases/tag/4.6.0.5 Note: If you come to this later and this link is dead, then just follow the instructions on the website: https://emby.media/download
Chep 0 Posted November 10, 2020 Posted November 10, 2020 So I was able to install the beta for OS 5 on my EX4100....when I click to configure it though, it won't connect at all. Any suggestions?
Luke 42237 Posted November 10, 2020 Posted November 10, 2020 3 hours ago, Chep said: So I was able to install the beta for OS 5 on my EX4100....when I click to configure it though, it won't connect at all. Any suggestions? Hi, what do you mean by won't connect?
Chep 0 Posted November 10, 2020 Posted November 10, 2020 1 hour ago, Luke said: Hi, what do you mean by won't connect? When I click on configure, it opens up to localhost:8096 but doesn't connect or load. It says the server can't be reached & it says the localhost refuses to connect unfortunately.
Rak85 0 Posted November 11, 2020 Posted November 11, 2020 (edited) On 11/10/2020 at 9:46 AM, Chep said: When I click on configure, it opens up to localhost:8096 but doesn't connect or load. It says the server can't be reached & it says the localhost refuses to connect unfortunately. Try typing your NAS IP address manually. NasIP:8096 Instead of localhost:8096 as that probably means you are looking for emby on the device you're browsing from (PC) Edited November 11, 2020 by Rak85 added quote
Chep 0 Posted November 11, 2020 Posted November 11, 2020 3 hours ago, Rak85 said: Try typing your NAS IP address manually. NasIP:8096 Instead of localhost:8096 as that probably means you are looking for emby on the device you're browsing from (PC) I should've specified that I have been putting in my NAS IP address....that's what I meant by "localhost"
prunhardt 3 Posted November 12, 2020 Posted November 12, 2020 (edited) I've installed the beta for OS5 succesfully on my WD EX2 Ultra, just to see if it works and will test performance. On the page Luke mentioned there are two versions. Make sure you use the one with OS5 in the name: https://github.com/MediaBrowser/Emby.Releases/releases/download/4.6.0.5/emby-server-western_digital_ex2_ultra_os5_4.6.0.5_arm.bin First Impression: I am pleasantly surprised by the functionality (e.g. remote server restart, automatic file detection). It all works, including transcoding, which went smoothly during the short time I tried it. The responsiveness of the UI is slow, though, much slower than the servers on my Nvidia Shield or PC. The EX2 is also working hard continuously CPU usage s constantly more than 50%, often higher than 80%. You can tell the EX2 is not really designed for this kind of apps. So I think I will stop using the server on the EX2 for that reason, but that shouldn;t stop anyone form trying it out themselves. Edited November 13, 2020 by prunhardt
TheDude12 0 Posted November 21, 2020 Posted November 21, 2020 (edited) On 11/11/2020 at 9:11 PM, Chep said: I should've specified that I have been putting in my NAS IP address....that's what I meant by "localhost" Hi, I'm having the exact same issue. After successful install of Emby on my EX4100, clicking the "configure" button opens up a new browser tab (with the correct IP address of my NAS and the correct port) and I get the "Safari can't connect to the server". I tried with different browsers and also from a windows machine. Same result. A similar issue was discussed elsewhere (https://emby.media/community/index.php?/topic/70731-mono-version-of-emby-server/page/5/) by tafelpoowt who found that some libs were missing due to an attempt to rebuild without cleaning the previous output. Could these two be related? I'm running firmware 5.05.111 on my EX4100 and tried with emby versions 4.6.0.6-beta and 4.6.0.5-beta (same issue). Trying to connect to emby via the emby app also does not work. Cheers Edited November 21, 2020 by TheDude12 added configuration details
justadude 2 Posted December 23, 2020 Posted December 23, 2020 (edited) Hello, found emby-server-western_digital_pr2100_os5_4.6.0.10_x86_64 on github. These are not linked on the website download page. As someone who does not spend a lot of time on github it took me a moment to navigate the site. The install was quick and the server is running. I had to update the links to the folders, but given the changes to the os in version 5 I suspected that might be the case. Save for the cases where I had to Identify media manually in my old install all preexisting metadata and images was found and applied after fixing my library. Thank you Edited December 23, 2020 by justadude
Luke 42237 Posted December 25, 2020 Posted December 25, 2020 Thanks for the feedback. We'll be getting these on the website soon.
JDizzy 21 Posted January 3, 2021 Posted January 3, 2021 I D/L the zip file but was not sure which file to install for the new OS5. I have a PR4100 If I try to install ones form the WD download page as mentioned above, I get the message the app is fior OS3.
Luke 42237 Posted January 4, 2021 Posted January 4, 2021 20 hours ago, JDizzy said: I D/L the zip file but was not sure which file to install for the new OS5. I have a PR4100 If I try to install ones form the WD download page as mentioned above, I get the message the app is fior OS3. You have to find the one with os5 in the file name.
JDizzy 21 Posted January 7, 2021 Posted January 7, 2021 (edited) Alright, I found it. Thanks Edited January 7, 2021 by JDizzy
Luke 42237 Posted January 7, 2021 Posted January 7, 2021 We'll be updating the website soon with os5 download info. Thanks.
