SoGX 4 Posted May 23, 2020 Posted May 23, 2020 (edited) Hallo zusammen, mir ist aufgefallen, dass der Sound unter o. g. Firefox Version bei manchen Filmen stottert. Untre Chrome und den selben Filmen funktioniert das Abspielen jedoch einwandfrei. Hab FF schon zurückgesetzt und es auch auf dem Laptop getestet, das Fehlerbild war immer das selbe. Hatte hier schon mal jemand ein ähnliches Problem und kann mir evtl. helfen, das Problem zu beheben? Gruß Stephan ffmpeg-transcode-b96d8dde-c3b0-4ec3-b668-5b6d0eb46eaf_1.txt Edited May 23, 2020 by SoGX
SoGX 4 Posted May 25, 2020 Author Posted May 25, 2020 (edited) Hello, everyone,I currently have a problem playing some videos with Firefox. The sound stutters.It doesn't matter if I increase or decrease the quality. It doesn't matter if I did software coding or hardware coding. Everything ends with the same result.I have already tested it with different devices, but this did not bring any success.But with other browsers the playback works fine, no matter if Chrome or Edge (new).Does anyone have a similar problem?Please note that this problem does not occur with every video. ffmpeg-transcode-7de0f904-15be-49ca-b1ba-9a5f6471f62c_1.txt embyserver.txt hardware_detection-63726046241.txt Edited May 25, 2020 by SoGX
Luke 42206 Posted June 4, 2020 Posted June 4, 2020 Hi there, are you still running into this? Does it only happen with DTS audio?
SoGX 4 Posted June 4, 2020 Author Posted June 4, 2020 Hi, yes the problem still exists and as far as I can currently tell it only affects the DTS sound.
Luke 42206 Posted June 8, 2020 Posted June 8, 2020 @@arrbee99 are you able to reproduce this in firefox?
arrbee99 1836 Posted June 8, 2020 Posted June 8, 2020 I tried playing various bits of bluray rips of movies which were all DTS5.1 and which all did Direct Streaming in Firefox. The audio seemed fine for all of them. If it matters, they were About Time, 2012, Bridge of Spies, Dad's Army, Forbidden Planet, The Incredibles. It was mentioned that not all videos were affected. Maybe there are more specific conditions I could try. This is Windows 10, latest Emby beta, Firefox on same PC as server.
SoGX 4 Posted June 8, 2020 Author Posted June 8, 2020 (edited) I have tested it with the Beta as well as with the Stable. On Windows 10 as well as Windows 2019 Server.Each time with the same result.@@arrbee99I have sent you a PM with the link to download the corresponding file. Maybe you can test it again with this one.I would say it is a problem with the file, but with the Chrome Browser and Edge Browser it works fine. Edited June 8, 2020 by SoGX
arrbee99 1836 Posted June 9, 2020 Posted June 9, 2020 Thanks. Got the file. Yes I get stuttering playing it with Firefox but with Chrome its OK. Direct Streaming with both browsers.
SoGX 4 Posted November 16, 2020 Author Posted November 16, 2020 Hello everyone, are there any news in this regard? Even in the current Emby version the problem still exists.
Luke 42206 Posted November 17, 2020 Posted November 17, 2020 Hi, if you lower the in app quality setting to force a full transcode, does it happen then?
SoGX 4 Posted November 17, 2020 Author Posted November 17, 2020 Hi, same problem with full transcode.
Luke 42206 Posted November 17, 2020 Posted November 17, 2020 We'll take another look at it. Thanks for reporting.
