negativzeroe 80 Posted May 25, 2020 Posted May 25, 2020 (edited) Ability to create a playlist rule set based on shows that are added, then re-generate a playlist each day of the Up Next for those shows. To create some sort of resemblance of after school cartoons and Saturday morning cartoons now that stream/binge culture has depreciated the idea. I know you guys are working on multi user playlists and such but it would be nice to add to the roadmap. Sent from my ONEPLUS A5000 using Tapatalk Edited May 25, 2020 by negativzeroe
ebr 16339 Posted May 25, 2020 Posted May 25, 2020 Hi. I believe this would just be a form of Smart Playlists no? 1
negativzeroe 80 Posted May 25, 2020 Author Posted May 25, 2020 I'll have to play and see thanks for pointing me to it. Sent from my ONEPLUS A5000 using Tapatalk
ebr 16339 Posted May 25, 2020 Posted May 25, 2020 Hi. I'm not suggesting the current 3rd party plug-in will do what you want - just that what you are asking for would be a form of a smart playlist so, hopefully, covered by that function when we get it into the server proper.
negativzeroe 80 Posted June 4, 2020 Author Posted June 4, 2020 Hi. I'm not suggesting the current 3rd party plug-in will do what you want - just that what you are asking for would be a form of a smart playlist so, hopefully, covered by that function when we get it into the server proper.Almost, but it needs some sort of next up variable. If I sort by release date and the shows are years apart it queues up a full show before the next. Sent from my ONEPLUS A5000 using Tapatalk
