zBernie 16 Posted May 25, 2020 Posted May 25, 2020 I just got the Emby backup plugin working. Nice! I see my playlists and user data backed up. But I don't see any of my movie collections backed up. I checked the files below, and there is no mention of my collections. I did a recursive grep from the backup directory on down, and no references to my collections. Are the collections supposed to be backed up? I want to make sure, because they involve a lot of work! ./library/Collections ./library/Collections/options.xml -Thanks
Solution zBernie 16 Posted May 25, 2020 Author Solution Posted May 25, 2020 I just got the Emby backup plugin working. Nice! I see my playlists and user data backed up. But I don't see any of my movie collections backed up. I checked the files below, and there is no mention of my collections. I did a recursive grep from the backup directory on down, and no references to my collections. Are the collections supposed to be backed up? I want to make sure, because they involve a lot of work! ./library/Collections ./library/Collections/options.xml -Thanks I believe I found the answer at the link below. The collections are backed up in the library.db file. "/ProgramData/data/library.db This will backup saved configurations, installed plugins, collections you've created, playlists, display preferences and the user database." https://support.emby.media/support/solutions/articles/44001159936-backup 1
