physicsman 0 Posted May 24, 2020 Posted May 24, 2020 (edited) Hi All, I'm running emby on a FreeNas/FreeBSD system and with the exception of this one issue, it's been fantastic! Whenever I try to play a video on my PS3 via DLNA that is encoded in H.264 with mp4 audio encoding, the video will play but no audio comes through. Other video types play perfectly (including audio). I've tried all I can think of and would love some help in solving this. I've attached screen caps of the codec info of an example video that presents this issue as well as of the Direct Play, Transcoding, and Codec pages of the PS3 DLNA profile. I've also pasted the log file for an example stream that presents this issue. I'm sure it's just some small noob thing that I'm missing. Thanks in advance!! 2020-05-24 19:35:33.897Emby Server version: 4.2.1.0App:http://192.168.1.20:8096/videos/41392/stream.ts?DeviceProfileId=54af1dc11a68aa2ba8ed3884515d5fc4&DeviceId=c584245573d7a93bc5263026a340058f&MediaSourceId=463835ddae75662bca46fe2799b806b5&PlaySessionId=0e80b03669b99fb7e91479ec771e8bbe&VideoCodec=h264&AudioCodec=ac3,aac,mp3&VideoBitrate=15360000&AudioBitrate=192000&MaxFramerate=30&MaxWidth=1920&MaxHeight=1080&AudioStreamIndex=1&h264-level=41&ac3-audiochannels=6&TranscodeReasons=ContainerNotSupported{"Protocol":"File","Id":"463835ddae75662bca46fe2799b806b5","Path":"/media/TVShows/BattleBots 2015 S04E01 REPACK 1080p WEB x264-TBS/battlebots.2015.s04e01.repack.1080p.web.x264-tbs.mkv","Type":"Default","Container":"mkv","Size":3194825196,"Name":"battlebots.2015.s04e01.repack.1080p.web.x264-tbs","IsRemote":false,"RunTimeTicks":50595630000,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"Codec":"h264","TimeBase":"1/1000","CodecTimeBase":"1001/60000","VideoRange":"SDR","DisplayTitle":"1080p H264","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":5051543,"BitDepth":8,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":29.97003,"RealFrameRate":29.97003,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuv420p","Level":40,"IsAnamorphic":false},{"Codec":"aac","TimeBase":"1/1000","CodecTimeBase":"1/48000","DisplayTitle":"AAC stereo (Default)","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"HE-AAC","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","Level":0}],"Formats":[],"Bitrate":5051543,"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false}/usr/local/bin/ffmpeg -f matroska -i file:"/media/TVShows/BattleBots 2015 S04E01 REPACK 1080p WEB x264-TBS/battlebots.2015.s04e01.repack.1080p.web.x264-tbs.mkv" -map 0:0 -map 0:1 -sn -c:v:0 copy -bsf:v h264_mp4toannexb -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 copy -disposition:a:0 default -y "/var/db/emby-server/transcoding-temp/a46036bba24b813e4a73a4ffa7c61e9d.ts"ffmpeg version 4.2.1 Copyright © 2000-2019 the FFmpeg developersbuilt with FreeBSD clang version 6.0.0 (tags/RELEASE_600/final 326565) (based on LLVM 6.0.0)configuration: --prefix=/usr/local --mandir=/usr/local/man --datadir=/usr/local/share/ffmpeg --pkgconfigdir=/usr/local/libdata/pkgconfig --enable-shared --enable-pic --enable-gpl --enable-avresample --cc=cc --disable-alsa --disable-libopencore-amrnb --disable-libopencore-amrwb --enable-libaom --disable-libaribb24 --disable-libass --disable-libbs2b --disable-libcaca --disable-libcdio --disable-libcelt --disable-libcodec2 --enable-libdav1d --disable-libdavs2 --disable-libdc1394 --disable-debug --enable-htmlpages --disable-libdrm --enable-libfdk-aac --disable-libflite --enable-fontconfig --enable-libfreetype --enable-frei0r --disable-libfribidi --disable-gcrypt --disable-libgme --enable-gmp --enable-gnutls --enable-version3 --disable-libgsm --enable-iconv --disable-libilbc --disable-libjack --disable-libklvanc --disable-libkvazaar --disable-ladspa --enable-libmp3lame --disable-liblensfun --disable-libbluray --disable-librsvg --disable-librtmp --disable-libxml2 --disable-lv2 --disable-mbedtls --enable-mmx --disable-libmodplug --disable-libmysofa --enable-nonfree --disable-openal --disable-opencl --enable-libopencv --disable-opengl --disable-libopenh264 --disable-libopenjpeg --disable-libopenmpt --disable-openssl --enable-optimizations --enable-libopus --disable-pocketsphinx --disable-libpulse --disable-librav1e --enable-runtime-cpudetect --disable-librubberband --enable-sdl2 --disable-libsmbclient --disable-libsnappy --disable-sndio --disable-libsoxr --disable-libspeex --disable-libsrt --enable-sse --disable-libssh --disable-libtensorflow --disable-libtesseract --enable-libtheora --disable-libtwolame --enable-libv4l2 --enable-vaapi --disable-vapoursynth --enable-vdpau --disable-libvidstab --disable-libvmaf --enable-libvorbis --disable-libvo-amrwbenc --enable-libvpx --disable-libwavpack --disable-libwebp --enable-libx264 --enable-libx265 --disable-libxavs2 --enable-libxcb --enable-libxvid --disable-outdev=xv --disable-libzimg --disable-libzmq --disable-libzvbilibavutil 56. 31.100 / 56. 31.100libavcodec 58. 54.100 / 58. 54.100libavformat 58. 29.100 / 58. 29.100libavdevice 58. 8.100 / 58. 8.100libavfilter 7. 57.100 / 7. 57.100libavresample 4. 0. 0 / 4. 0. 0libswscale 5. 5.100 / 5. 5.100libswresample 3. 5.100 / 3. 5.100libpostproc 55. 5.100 / 55. 5.100Input #0, matroska,webm, from 'file:/media/TVShows/BattleBots 2015 S04E01 REPACK 1080p WEB x264-TBS/battlebots.2015.s04e01.repack.1080p.web.x264-tbs.mkv':Metadata:encoder : libebml v1.3.6 + libmatroska v1.4.9creation_time : 2019-06-08T00:51:17.000000ZDuration: 01:24:19.56, start: 0.000000, bitrate: 5051 kb/sStream #0:0: Video: h264 (High), yuv420p(progressive), 1920x1080, SAR 1:1 DAR 16:9, 29.97 fps, 29.97 tbr, 1k tbn, 96k tbc (default)Metadata:BPS-eng : 4922529DURATION-eng : 01:24:19.454000000NUMBER_OF_FRAMES-eng: 151632NUMBER_OF_BYTES-eng: 3113163735_STATISTICS_WRITING_APP-eng: mkvmerge v24.0.0 ('Beyond The Pale') 64-bit_STATISTICS_WRITING_DATE_UTC-eng: 2019-06-08 00:51:17_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTESStream #0:1: Audio: aac (HE-AAC), 48000 Hz, stereo, fltp (default)Metadata:BPS-eng : 126701DURATION-eng : 01:24:19.563000000NUMBER_OF_FRAMES-eng: 118587NUMBER_OF_BYTES-eng: 80131595_STATISTICS_WRITING_APP-eng: mkvmerge v24.0.0 ('Beyond The Pale') 64-bit_STATISTICS_WRITING_DATE_UTC-eng: 2019-06-08 00:51:17_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTESOutput #0, mpegts, to '/var/db/emby-server/transcoding-temp/a46036bba24b813e4a73a4ffa7c61e9d.ts':Metadata:encoder : Lavf58.29.100Stream #0:0: Video: h264 (High), yuv420p(progressive), 1920x1080 [sAR 1:1 DAR 16:9], q=2-31, 29.97 fps, 29.97 tbr, 90k tbn, 1k tbc (default)Stream #0:1: Audio: aac (HE-AAC), 48000 Hz, stereo, fltp (default)Stream mapping:Stream #0:0 -> #0:0 (copy)Stream #0:1 -> #0:1 (copy)Press [q] to stop, [?] for helpframe= 2093 fps=0.0 q=-1.0 size= 47104kB time=00:01:09.97 bitrate=5514.6kbits/s speed= 140xframe= 4354 fps=4311 q=-1.0 size= 97536kB time=00:02:25.40 bitrate=5495.0kbits/s speed= 144xframe= 6324 fps=4145 q=-1.0 size= 141312kB time=00:03:31.11 bitrate=5483.4kbits/s speed= 138xframe= 7464 fps=3670 q=-1.0 size= 167424kB time=00:04:09.25 bitrate=5502.5kbits/s speed= 123xframe= 9243 fps=3584 q=-1.0 size= 207104kB time=00:05:08.56 bitrate=5498.3kbits/s speed= 120xframe=11992 fps=3888 q=-1.0 size= 268544kB time=00:06:40.25 bitrate=5496.3kbits/s speed= 130xframe=13903 fps=3879 q=-1.0 size= 311552kB time=00:07:44.17 bitrate=5498.5kbits/s speed= 130xframe=15617 fps=3824 q=-1.0 size= 349952kB time=00:08:41.21 bitrate=5500.2kbits/s speed= 128xframe=17470 fps=3716 q=-1.0 size= 391168kB time=00:09:42.99 bitrate=5496.5kbits/s speed= 124xframe=18079 fps=3466 q=-1.0 size= 404992kB time=00:10:03.47 bitrate=5497.6kbits/s speed= 116xframe=21007 fps=3675 q=-1.0 size= 470528kB time=00:11:41.09 bitrate=5497.9kbits/s speed= 123xframe=23089 fps=3694 q=-1.0 size= 516864kB time=00:12:50.41 bitrate=5495.9kbits/s speed= 123xframe=24893 fps=3669 q=-1.0 size= 557568kB time=00:13:50.80 bitrate=5497.8kbits/s speed= 122xframe=26956 fps=3697 q=-1.0 size= 603904kB time=00:14:59.54 bitrate=5499.7kbits/s speed= 123xframe=29218 fps=3748 q=-1.0 size= 653568kB time=00:16:14.92 bitrate=5491.7kbits/s speed= 125xframe=31036 fps=3732 q=-1.0 size= 694016kB time=00:17:15.63 bitrate=5489.7kbits/s speed= 125xframe=32183 fps=3630 q=-1.0 size= 719360kB time=00:17:53.86 bitrate=5487.6kbits/s speed= 121xframe=33942 fps=3607 q=-1.0 size= 758784kB time=00:18:52.57 bitrate=5488.3kbits/s speed= 120xframe=35802 fps=3604 q=-1.0 size= 800256kB time=00:19:54.61 bitrate=5487.7kbits/s speed= 120xframe=37601 fps=3602 q=-1.0 size= 840192kB time=00:20:54.77 bitrate=5485.3kbits/s speed= 120xframe=40184 fps=3636 q=-1.0 size= 897792kB time=00:22:20.83 bitrate=5485.2kbits/s speed= 121xframe=41357 fps=3529 q=-1.0 size= 923904kB time=00:22:59.95 bitrate=5484.7kbits/s speed= 118xframe=42983 fps=3505 q=-1.0 size= 960256kB time=00:23:54.21 bitrate=5484.8kbits/s speed= 117xframe=43677 fps=3408 q=-1.0 size= 975616kB time=00:24:17.53 bitrate=5483.4kbits/s speed= 114xframe=45334 fps=3402 q=-1.0 size= 1012992kB time=00:25:12.65 bitrate=5486.0kbits/s speed= 114xframe=46811 fps=3378 q=-1.0 size= 1046016kB time=00:26:01.98 bitrate=5486.0kbits/s speed= 113xframe=48032 fps=3346 q=-1.0 size= 1073664kB time=00:26:42.68 bitrate=5487.9kbits/s speed= 112xframe=49719 fps=3342 q=-1.0 size= 1111296kB time=00:27:39.09 bitrate=5487.2kbits/s speed= 112xframe=50416 fps=3271 q=-1.0 size= 1126912kB time=00:28:02.43 bitrate=5487.1kbits/s speed= 109xframe=50858 fps=3149 q=-1.0 size= 1136640kB time=00:28:17.23 bitrate=5486.2kbits/s speed= 105xframe=51816 fps=3112 q=-1.0 size= 1158400kB time=00:28:49.02 bitrate=5488.4kbits/s speed= 104xframe=53324 fps=3109 q=-1.0 size= 1191936kB time=00:29:39.32 bitrate=5487.7kbits/s speed= 104xframe=55233 fps=3128 q=-1.0 size= 1234944kB time=00:30:42.98 bitrate=5489.3kbits/s speed= 104xframe=56557 fps=3115 q=-1.0 size= 1264640kB time=00:31:27.14 bitrate=5489.7kbits/s speed= 104xframe=58299 fps=3093 q=-1.0 size= 1302784kB time=00:32:25.51 bitrate=5485.7kbits/s speed= 103xframe=58539 fps=3052 q=-1.0 Lsize= 1308544kB time=00:32:33.36 bitrate=5487.8kbits/s speed= 102xvideo:1175721kB audio:30212kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 8.508821% Edited May 24, 2020 by physicsman
Luke 42237 Posted June 4, 2020 Posted June 4, 2020 Hi, is the audio that the server is sending not compatible ,do you know?
pedrobotton 0 Posted September 27, 2020 Posted September 27, 2020 I'm having the same problem, all my videos run without audio and without subtitles on Playstation 3, is there any solution to this problem? The same videos on the same network via Chromecast work smoothly. I'm thinking a lot about subscribing to Emby Premiere but only if the videos work with sound and subtitles on Playstation 3 otherwise it won't be worth it for me. Hope there is an answer, a hug from Brazil.
Luke 42237 Posted September 28, 2020 Posted September 28, 2020 On 9/27/2020 at 12:56 AM, pedrobotton said: I'm having the same problem, all my videos run without audio and without subtitles on Playstation 3, is there any solution to this problem? The same videos on the same network via Chromecast work smoothly. I'm thinking a lot about subscribing to Emby Premiere but only if the videos work with sound and subtitles on Playstation 3 otherwise it won't be worth it for me. Hope there is an answer, a hug from Brazil. Hi there, can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
