Kippenhof 0 Posted May 24, 2020 Posted May 24, 2020 (edited) Hey Guys, My Emby Server Cant Load the Plugin Caterlog, The Metadata of new Movies and gives me this Error Message on my DashboardCancelling connection to https://www.mb3admin.com/admin/service/EmbyPackages.json due to a previous timeout. at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod)at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod)at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePackagesWithoutRegistrationInfo(Boolean enableCache, CancellationToken cancellationToken)at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePluginUpdates(Version applicationVersion, CancellationToken cancellationToken)at Emby.Server.Implementations.ScheduledTasks.PluginUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress)at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Catalog Edited May 24, 2020 by Kippenhof
Luke 42213 Posted May 24, 2020 Posted May 24, 2020 Hi there, this generally means something is blocking your connection to our admin server, such as a firewall, security software, or VPN. Can you look into this? 1
Kippenhof 0 Posted May 25, 2020 Author Posted May 25, 2020 Hi there, this generally means something is blocking your connection to our admin server, such as a firewall, security software, or VPN. Can you look into this? Thank you, ill Check it
Solution Kippenhof 0 Posted May 25, 2020 Author Solution Posted May 25, 2020 (edited) For People they have The Same Problem: In my Case the Problem was the Program Hamatchi.If you have the Same Problem just uninstall it. Edited May 25, 2020 by Kippenhof
