jsc1205 51 Posted May 22, 2020 Posted May 22, 2020 I just added 2 versions of Blade Runner to Emby along with a trailer and some extras. I added the first version of the movie from one disc, then the making of from a second disc. Then after ripping the 2nd version of the movie along with additional extras, now no extras or trailers show up at all. I have merged the to versions of the movie in Emby, split them and still, no extras/trailers. I checked the naming convention and I have them as "extras" and "trailers". I even moved these folders to a different movie and they showed up just fine. But when I move them back to the Blade Runner folder, they disappear again. So I'm completely stumped. Thanks for any help you can provide
Luke 42203 Posted May 22, 2020 Posted May 22, 2020 Hi there, how have you named and organized the files?
Bigmack3000 108 Posted May 22, 2020 Posted May 22, 2020 (edited) This sounds exactly like the issue I've been having with multi-version films. It blocks the extras from showing up on Emby. https://emby.media/community/index.php?/topic/84682-extrasspecialsdeleted-scenes-and-movies-with-multiple-versions/ Edited May 22, 2020 by Bigmack3000
jsc1205 51 Posted May 22, 2020 Author Posted May 22, 2020 (edited) Hi there, how have you named and organized the files? /Movies /Blade Runner (1982) /Blade Runner (1982) - Final Cut 2007.mkv /Blade Runner (1982) - Workprint.mkv /behind the scenes /All Our Variant Futures.mkv /Dangerous Days - Making of Blade Runner.mkv /Enhancement Archive.mkv /Workprint Introduction.mkv / trailers /trailer.mkv Edited May 22, 2020 by jsc1205
Luke 42203 Posted May 22, 2020 Posted May 22, 2020 Yes this is resolved for the next release. Thanks.
crusher11 1134 Posted May 22, 2020 Posted May 22, 2020 Is it resolved in the current beta? I accidentally left a stub file in a movie's folder after adding the MKV, and when I removed it I ended up with two copies of every extra. One copy had a thumbnail and one didn't. Rescanned and it was fixed, although the thumbnail versions were the ones that were removed.
spon 26 Posted March 4, 2021 Posted March 4, 2021 Hi guys. Just checking to see if the fix for this was released. I'm currently having what I think is the same issue. The movie versions group fine but the extras show as separate "movies" /moviename (year) /moviename (year)/moviename (year) - 3D /moviename (year)/moviename (year) - 1080p /moviename (year)/extras/extra 1 /moviename (year)/extras/extra 2 /moviename (year)/extras/extra 3
Luke 42203 Posted March 4, 2021 Posted March 4, 2021 Hi, yes this is from a year ago. Please go over a specific example. thanks.
Happy2Play 9802 Posted March 4, 2021 Posted March 4, 2021 16 minutes ago, spon said: Hi guys. Just checking to see if the fix for this was released. I'm currently having what I think is the same issue. The movie versions group fine but the extras show as separate "movies" /moviename (year) /moviename (year)/moviename (year) - 3D /moviename (year)/moviename (year) - 1080p /moviename (year)/extras/extra 1 /moviename (year)/extras/extra 2 /moviename (year)/extras/extra 3 Haven't seen a issue.
spon 26 Posted March 4, 2021 Posted March 4, 2021 Thanks for the super quick reply, as always. Here are some screenshots. I'm sure I'm doing something wrong but can't see what it is. I have quite a few movies with multiple versions, but this is the first one that I've added extras too. There are 2 movie versions and then 3 other files in the extras folder. All 5 are showing as independent movies. Thanks again.
Happy2Play 9802 Posted March 4, 2021 Posted March 4, 2021 @sponHave you removed, scanned, then re-added this media? If that does not work, can you test creating a new library with a new folder path and placing this media in the new library to see if you get the same results.
spon 26 Posted March 5, 2021 Posted March 5, 2021 @Happy2Play no luck with either option. In both cases, all 5 video files show as separate movies. Honestly not a huge deal b/c I don't really care about the extras so I'll probably just delete them. Definitely something weird going on though.
Happy2Play 9802 Posted March 5, 2021 Posted March 5, 2021 (edited) Okay there may be a issue as your folder name and file names actually does not conform to multi-version requirements. Sure the would with the plug but don't know about extras in this overall situation. @spon Multi-version movies Multiple versions of the same content can be stored in a single movie folder. /Movies /300 (2006) /300 (2006)/300 (2006) - 1080p.mkv /300 (2006)/300 (2006) - 1080p-trailer.mp4 /300 (2006)/300 (2006) - 4K.mkv /300 (2006)/300 (2006) - 720p.mp4 /300 (2006)/300 (2006) - extended edition.mp4 /300 (2006)/300 (2006) - directors cut.mp4 /300 (2006)/300 (2006) - 3D.hsbs.mp4 Each version must begin with the folder name, followed by " - ". Not sure this will work at all with your current naming scheme. Edited March 5, 2021 by Happy2Play
spon 26 Posted March 5, 2021 Posted March 5, 2021 You are absolutely right. I forgot the "-" that's needed. Can't believe I didn't catch that. Thanks for your help! 1
