Marcus1305 19 Posted January 29 Posted January 29 (edited) Thanks for confirming. As we know, it’s certainly possible, and it would be great to see this implemented on Tizen as soon as possible. Any updates or plans to move forward with it? Edited January 29 by Marcus1305
crusher11 1143 Posted January 30 Posted January 30 13 hours ago, Reaper47 said: This would be the best solution. Preferably also configurable, as either disabled (no dimmind), dim only UI, dim only subtitles or dim everything (like in Kodi). The Kodi option is a slider, not a toggle. 1
Marcus1305 19 Posted January 31 Posted January 31 On 1/30/2026 at 4:05 AM, Luke said: Hi, yes we can add more options for this. Thanks. Thanks. Just to be clear, the main ask is a quick subtitle settings menu accessible from the player, not just additional global subtitle options.
Reaper47 13 Posted January 31 Posted January 31 @Marcus1305Yes, that would be the best first step, as such menu already exist in android app (and maybe web app, not sure right now). Hopefully it will soon be brought into more apps. But later on, having something like Kodi would be ideal.
