sbz71 0 Posted May 21, 2020 Posted May 21, 2020 Forgive me if this issue has been posted somewhere else as Ive searched all over and couldn't find anything that helped. I just reinstalled centos 7 and installed the latest stable version of Emby. No mater what I've tried to do it will not start. Out of frustration I installed centos 8 and installed the lasted bata version from the download page and it still will not start. I've been running an Emby server for years and I've never had this problem before. below is the output from the service status of Emby. emby-server.service - Emby Server is a personal media server with apps on just about every device. Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: disabled) Active: failed (Result: core-dump) since Thu 2020-05-21 12:26:31 EDT; 14s ago Process: 5717 ExecStart=/opt/emby-server/bin/emby-server (code=dumped, signal=ABRT) Main PID: 5717 (code=dumped, signal=ABRT) May 21 12:26:30 emby.clent.net emby-server[5717]: at System.IO.FileSystem.CreateDirectory(String fullPath) May 21 12:26:30 emby.clent.net emby-server[5717]: at System.IO.Directory.CreateDirectory(String path) May 21 12:26:30 emby.clent.net emby-server[5717]: at Emby.Server.Implementations.Logging.FileLogger..ctor(String path) May 21 12:26:30 emby.clent.net emby-server[5717]: at Emby.Server.Implementations.Logging.SimpleLogManager.ReloadLogger(LogSeverity severity, CancellationToken cancellationToken) May 21 12:26:30 emby.clent.net emby-server[5717]: --- End of inner exception stack trace --- May 21 12:26:30 emby.clent.net emby-server[5717]: at System.Threading.Tasks.Task.WaitAllCore(Task[] tasks, Int32 millisecondsTimeout, CancellationToken cancellationToken) May 21 12:26:30 emby.clent.net emby-server[5717]: at System.Threading.Tasks.Task.WaitAll(Task[] tasks) May 21 12:26:30 emby.clent.net emby-server[5717]: at EmbyServer.Program.Main(String[] args) May 21 12:26:31 emby.clent.net systemd[1]: emby-server.service: Main process exited, code=dumped, status=6/ABRT May 21 12:26:31 emby.clent.net systemd[1]: emby-server.service: Failed with result 'core-dump'. ~
Q-Droid 1011 Posted May 22, 2020 Posted May 22, 2020 Was the path to /var/lib/emby created? It's the emby home directory owned by emby:emby. The errors in your log appear to be related to permissions for file access and creation.
sbz71 0 Posted May 22, 2020 Author Posted May 22, 2020 Yeah It was a permissions issue. I added the correct permissions and now the server it running perfectly.
jaspion1981 0 Posted October 19, 2020 Posted October 19, 2020 Boa noite...instalei meu servidor emby no Centos 8 e o servidor não quer iniciar de jeito nem um. algum pode mim ajudar.
jaspion1981 0 Posted October 20, 2020 Posted October 20, 2020 qual a solução que você teve ? estou com o mesmo problema.
jaspion1981 0 Posted October 20, 2020 Posted October 20, 2020 On 21/05/2020 at 23:45, Q-Droid said: O caminho para / var / lib / emby foi criado? É o diretório inicial emby de propriedade de emby: emby. Os erros em seu log parecem estar relacionados às permissões para acesso e criação de arquivos. mim ajuda resolveu o problema que e o mesmo do amigo topico.
Luke 42246 Posted October 20, 2020 Posted October 20, 2020 Hi @jaspion1981, please see my response here: Thanks.
jaspion1981 0 Posted October 20, 2020 Posted October 20, 2020 Fiz os procedimento; o servidor não inicia de maneira algum.
jaspion1981 0 Posted October 20, 2020 Posted October 20, 2020 On 21/05/2020 at 23:45, Q-Droid said: O caminho para / var / lib / emby foi criado? É o diretório inicial emby de propriedade de emby: emby. Os erros em seu log parecem estar relacionados às permissões para acesso e criação de arquivos. Comofaço para criar o arquivo ?
Q-Droid 1011 Posted October 20, 2020 Posted October 20, 2020 AGAIN - Post output from: ls -la /var/lib/emby
