Waldoo 14 Posted May 19, 2020 Posted May 19, 2020 (edited) Pugins -Movie Theme Videos -Movie Theme Songs -TV Theme Videos -TV Theme Songs On pc everything works, On Android the background video doesn't play but theme song is fine. And on fire tv the theme song and video doesn't work. Do I need the the emby pass for the premium apps? Edited May 19, 2020 by Waldoo
Luke 42212 Posted May 20, 2020 Posted May 20, 2020 Hi, no it's just that we haven't added these features to those apps. It's something we can look at in future updates. Thanks. 1
Waldoo 14 Posted May 20, 2020 Author Posted May 20, 2020 @@Luke I found out that theme songs and background images are off by default. In the Fire TV app which is very confusing imo. And if you do video backgrounds in Android and FireTV apps can you make a option to change the transparency its too dark for me. Ty
ebr 16310 Posted May 20, 2020 Posted May 20, 2020 Hi. Theme songs are supported in the Android/Fire TV app. I think you found that they were not enabled in app settings, correct?
Waldoo 14 Posted May 20, 2020 Author Posted May 20, 2020 Yea its just confusing, they should be on by default imo.
