alteci 0 Posted May 19, 2020 Posted May 19, 2020 (edited) In my music library, I have 15 folders...in the folder view, they don't show up correctly, and in the album view, lots of incorrect songs are in the wrong albums. Most of my songs are singles, not albums, but emby is grouping them and doing so incorrectly. How do I fix it? I've tried deleting all cache and metadata files, to no avail. As a side note...I've only been aware of Emby for about 1 week, I purchased the premiere version a couple days ago (I like what I see) and expected dedicated support, I'm a little disappointed premiere doesn't come with dedicated support, I may have purchased to early, but hoping to get this resolved here. I've also turned off nfo and metadata servers on this library and refreshed the libary and metadata, to no avail. The first screen shot shows in shell, the number and correct names of the music folders. The second screen shot shows emby player, showing the wrong folder names and wrong images, but showing the correct number of 15 folders. The third screen shot shows an album with wrong songs in the album, grouping songs that don't belong. Edited May 19, 2020 by alteci
PenkethBoy 2068 Posted May 19, 2020 Posted May 19, 2020 Hi Welcome music need the following structure .../AlbumArtist/Album/songs also you need to ensure your metadata tags are accurate - most people think they are but some work is required to ensure they are if you search the forums you will find numerous posts where people had problems with music and 99% of the time its folder structure and metadata tags that are the problem Emby uses the metadata tags to work out the way to present the songs/Albums etc with the help of the structure above Also check out the wiki on music naming etc for some additional guidance Have Fun
alteci 0 Posted May 19, 2020 Author Posted May 19, 2020 (edited) Thanks PenkethBoy! Is there anyway around this? I DJ and I have my music organized for me, for DJ'ing, i.e. year, genre, etc., it's stored on my laptop/Mac and I'm just copying the folder to my Emby server...it would be a LOT of work to 1) re-organize it, and then 2) re-organize every time I have new music to publish, and 3) need to keep track of two different sets of the same music folders. Any suggestions? Thanks again. And why wouldn't the Folder view show the actual folders? Edited May 19, 2020 by alteci
PenkethBoy 2068 Posted May 19, 2020 Posted May 19, 2020 folder view does show the folders Not much i can suggest re how emby works Luke has been promising for over a year to add a more flexible folder structure but nothing yet
alteci 0 Posted May 19, 2020 Author Posted May 19, 2020 See the screen shots I included in the original post, it's actually not correctly showing the folders in folder view, so perhaps there's a bug. The shell shows the correct folders.
PenkethBoy 2068 Posted May 19, 2020 Posted May 19, 2020 (edited) if you have the correct supported structure it will Edited May 19, 2020 by PenkethBoy
alteci 0 Posted May 20, 2020 Author Posted May 20, 2020 Ok, thanks, that seems strange that folder view doesn't actually show the correct folders if the structure is not correct. I did notice something, I deleted library.db and restarted my emby server...in the first few mins of it being up, it showed the correct folder structure, then as it completed the file scan, it went back to being messed up.
Luke 42237 Posted May 20, 2020 Posted May 20, 2020 Luke has been promising for over a year to add a more flexible folder structure but nothing yet Yup, trying hard to get myself freed up for it, just like i was with virtual scrolling.
alteci 0 Posted May 21, 2020 Author Posted May 21, 2020 Yup, trying hard to get myself freed up for it, just like i was with virtual scrolling. Good to know and thanks.
alteci 0 Posted May 21, 2020 Author Posted May 21, 2020 Mixed content type seems better for the music and displays more accurately. I did change the layout a bit, but even with the new layout, that aligns closer to the emby requirements, it still messes up the folder view if I use music content type. So seems looks like there is a bug in the "folder" view. For now, I'll keep it in mixed content type.
Luke 42237 Posted December 10, 2020 Posted December 10, 2020 Coming in Emby Server 4.6: https://emby.media/community/index.php?/topic/92417-4607-music-scanning-rewrite/
