lgpmichael 0 Posted May 19, 2020 Posted May 19, 2020 So, I've searched for an answer, I can't find one. Apologies if this has already been answeredExample show:/tv/Futurama/Season_1/01_Space_Pilot_3000.mp4The parser detects this as Futurama season 30 episode 00 This happens with any show which has a 3 or 4 digit number in the title. It seems to ignore the initial 01_This also happens with SG1/Season_2/21_1969.mp4 detects as season 19 episode 69South_Park/Season_1/02_Weight_Gain_4000.mp4 is season 40 episode 00Jessica_Jones/Season_1/10_AKA_1000_Cuts.mp4 is season 10 episode 00 Captain_Scarlet/Original/Season_1/13_Point_783.mp4 is season 7 eposide 83 (NOTE: This show was identified at the "Original" level, using the IMDB number). All other episodes around it are detected correctly, as long as they don't have a 3/4 digit number.This seems like a fairly definite bug. I can appreciate that the parser will be complex and a fix may be problematic, but, possibly an "identify" option at episode level so I can force it to work out what it should be with an IMDB/tvdb number would be helpful, and would allow people to resolve these issues without needing to fix the parser for every little problem.Version 4.4.2.0I can't find a specific logfile which mentions this.
mastrmind11 722 Posted May 19, 2020 Posted May 19, 2020 So, I've searched for an answer, I can't find one. Apologies if this has already been answered Example show: /tv/Futurama/Season_1/01_Space_Pilot_3000.mp4 The parser detects this as Futurama season 30 episode 00 This happens with any show which has a 3 or 4 digit number in the title. It seems to ignore the initial 01_ This also happens with SG1/Season_2/21_1969.mp4 detects as season 19 episode 69 South_Park/Season_1/02_Weight_Gain_4000.mp4 is season 40 episode 00 Jessica_Jones/Season_1/10_AKA_1000_Cuts.mp4 is season 10 episode 00 Captain_Scarlet/Original/Season_1/13_Point_783.mp4 is season 7 eposide 83 (NOTE: This show was identified at the "Original" level, using the IMDB number). All other episodes around it are detected correctly, as long as they don't have a 3/4 digit number. This seems like a fairly definite bug. I can appreciate that the parser will be complex and a fix may be problematic, but, possibly an "identify" option at episode level so I can force it to work out what it should be with an IMDB/tvdb number would be helpful, and would allow people to resolve these issues without needing to fix the parser for every little problem. Version 4.4.2.0 I can't find a specific logfile which mentions this. Open the metadata editor from your server dashboard and go to town.
Luke 42246 Posted May 19, 2020 Posted May 19, 2020 Hi, episodes with numbers can be a challenge. You can use the metadata editor as suggested. For automatic recognition you'll probably get a better result by using one of the stronger naming conventions, so instead of: 01 title.mkv You could try S01e01 title.mkv Please let us know if this helps. Thanks.
lgpmichael 0 Posted May 20, 2020 Author Posted May 20, 2020 Hi, episodes with numbers can be a challenge. You can use the metadata editor as suggested. For automatic recognition you'll probably get a better result by using one of the stronger naming conventions, so instead of: 01 title.mkv You could try S01e01 title.mkv Please let us know if this helps. Thanks. Hi Yep, that works. Unfortunately I can't use it, as renaming thousands of files, I could do that in a script, but then my cloud backup service would then want to re-upload 25TB and that would be - painful. At least there's a solution for people not shackled to a naming convention, and I CAN edit metadata, I was just hoping to not have to, it's a bit of a pain to get as much data as the autodetect does. I'd still definitely love to see an "identify" option at the episode level. I'll try and find some free time to dig through the code if that bit is still open, see if I can see why it's done it. It feels like it's a greedy regex, but as I've never looked at the code, that's a complete guess {;-) Thanks, and thanks to all the authors!
Luke 42246 Posted May 20, 2020 Posted May 20, 2020 @@Happy2Play @@PenkethBoy may have some tips on tools to help with mass renaming. Or alternatively you don't need to do it for all episodes, just the problem ones such as these.
lgpmichael 0 Posted May 20, 2020 Author Posted May 20, 2020 Oh no, the renaming isn't a problem, I can write scripts in my sleep. It's the fact that the cloud backup I use isn't something I can tell it to rename files, so it'll just say "oh, new name, need to re-upload it." No way round it unfortunately.Thanks anyway though!
