sesipod 0 Posted May 19, 2020 Posted May 19, 2020 (edited) 2020-05-18 18:57:28.421 Error App: Error getting connection info *** Error Report *** Version: 4.4.2.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.19.0.9 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 2 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: Name or service not known ---> System.Net.Sockets.SocketException (0xFFFDFFFF): Name or service not known at System.Net.Http.ConnectHelper.ConnectAsync(String host, Int32 port, CancellationToken cancellationToken) --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Connect.ConnectEntryPoint.GetIpAddress(String lookupUrl) at Emby.Server.Connect.ConnectEntryPoint.TimerCallback(Object state) Source: Emby.Server.Implementations TargetSite: Void MoveNext() InnerException: System.Net.Sockets.SocketException: Name or service not known Source: System.Private.CoreLib TargetSite: Void Throw() at System.Net.Http.ConnectHelper.ConnectAsync(String host, Int32 port, CancellationToken cancellationToken) 2020-05-18 18:57:28.510 Error HttpClient: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>402</errorCode><errorDescription>InvalidArgs</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope> 2020-05-18 18:57:28.536 Error HttpClient: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>402</errorCode><errorDescription>InvalidArgs</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope> 2020-05-18 18:57:28.539 Error PortMapper: Error creating port map *** Error Report *** Version: 4.4.2.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.19.0.9 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 2 Program data path: /var/lib/emby Application directory: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: InternalServerError at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Mono.Nat.Upnp.UpnpNatDevice.GetSpecificMappingAsync(Protocol protocol, Int32 publicPort, CancellationToken cancellationToken) at Mono.Nat.Upnp.UpnpNatDevice.CreatePortMap(Mapping mapping, CancellationToken cancellationToken) at Emby.PortMapper.ExternalPortForwarding.CreateRules(INatDevice device, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2020-05-18 18:57:28.566 Error HttpClient: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>402</errorCode><errorDescription>InvalidArgs</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope> 2020-05-18 18:57:28.589 Error HttpClient: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>402</errorCode><errorDescription>InvalidArgs</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope> 2020-05-18 18:57:28.592 Error PortMapper: Error creating port map *** Error Report *** Version: 4.4.2.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.19.0.9 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 2 Program data path: /var/lib/emby Application directory: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: InternalServerError at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Mono.Nat.Upnp.UpnpNatDevice.GetSpecificMappingAsync(Protocol protocol, Int32 publicPort, CancellationToken cancellationToken) at Mono.Nat.Upnp.UpnpNatDevice.CreatePortMap(Mapping mapping, CancellationToken cancellationToken) at Emby.PortMapper.ExternalPortForwarding.CreateRules(INatDevice device, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() Microsoft Windows [Version 10.0.18362.175] © 2019 Microsoft Corporation. All rights reserved. C:\Users\Administrator>ping schemas.xmlsoap.org Pinging e13878.b.akamaiedge.net [23.199.160.97] with 32 bytes of data: Reply from 23.199.160.97: bytes=32 time=36ms TTL=64 Reply from 23.199.160.97: bytes=32 time=39ms TTL=64 Reply from 23.199.160.97: bytes=32 time=43ms TTL=64 Reply from 23.199.160.97: bytes=32 time=36ms TTL=64 Ping statistics for 23.199.160.97: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 36ms, Maximum = 43ms, Average = 38ms C:\Users\Administrator> Edited May 19, 2020 by sesipod
Cthalpa 11 Posted May 24, 2020 Posted May 24, 2020 1) Why are you showing us, that you can ping from your own PC, when it's the server that has an issue? 2) InnerException: System.Net.Sockets.SocketException: Name or service not known This could be a DNS issue, OR a ripple effect of your system not being able to MAP the PORT as shown below. 3) 2020-05-18 18:57:28.539 Error PortMapper: Error creating port map It's not an emby issue, its a dns and/or port issue.You should seek help with your distro vendor!
sesipod 0 Posted June 5, 2020 Author Posted June 5, 2020 Sorry I completely forgot to respond here. I will have a secondary check with the server and see if this is still an issue. I do not see any sort of playback or update issues with the server. I made this post more or less to see what emby is trying to do with this request and why is it connecting to there. As to the ping both systems are on the same DNS and both can reach the ip via ping just never posted the ping back from Linux but both are able to reach.
sesipod 0 Posted June 5, 2020 Author Posted June 5, 2020 3) 2020-05-18 18:57:28.539 Error PortMapper: Error creating port map So is emby trying to open a port for connections back to the sever? Something like upnp?
Luke 42246 Posted June 6, 2020 Posted June 6, 2020 3) 2020-05-18 18:57:28.539 Error PortMapper: Error creating port map So is emby trying to open a port for connections back to the sever? Something like upnp? That is the automatic port mapper feature.
