Wrongin 0 Posted May 18, 2020 Posted May 18, 2020 I keep getting an error message of "your account has exceeded the max streaming limit set by your Emby Administrator. Please contact for assistance" Why is this happening??? we pay for premium so why is there a limit? how do you set to unlimited?
rechigo 367 Posted May 18, 2020 Posted May 18, 2020 Emby would NEVER limit the amount of streams without you setting the limit You most likely enabled the stream limit on a server or per-user basis 1) check "max simultaneous video streams" under the network tab in the admin panel 2) check "max simultaneous video streams" under the user settings page on the admin panel for the user that is experiencing the error Sent from my Galaxy S10 1
Happy2Play 9802 Posted May 18, 2020 Posted May 18, 2020 Is this your server or are you connecting to some else's server?
