vidkun 10 Posted July 9, 2014 Posted July 9, 2014 Since I just did a clean install of an Openelec box with XBMB3C I figured I'd write a quick guide for new users interested in testing out XBMB3C and MBS. It's meant to be a no fluff, quick and dirty guide. Maybe I'll come back through and add pretty pictures for the illiterate later, but it's not a priority for me at the moment. Install Openelec and boot into XBMC Download the XBMB3C Repo and upload it to the downloads directory of your Openelec box In XBMC go to Addons, Choose 'Install from ZIP file', browse to the repo zip you just uploaded to your downloads directory, install it Go to Addons, Choose get more add ons, select the XBMB3C repo you installed, go to Video Addons, Choose 'XBMB3C', choose 'Install' Go to Addons, Choose get more add ons, select the XBMB3C repo you installed, go to Skins, Choose a skin you like (I recommend Aeon Nox Gotham), choose 'Install' Go to Programs, then XBMB3C, Press 'C' and choose Addon Settings, enter in your MBS information and tweak the settings how you like or leave most defaults Go to System, Appearance, at the bottom change settings level to 'Advanced' Go to 'Mode' section of Appearance settings, enable Media Browser modes Enjoy. 4
vidkun 10 Posted July 9, 2014 Author Posted July 9, 2014 Thanks. Just trying to give back where I can.
ripper 5 Posted July 16, 2014 Posted July 16, 2014 I followed this guide using the current release of XBMC in Windows and it worked great. Then I installed the current release of OpenElec (4.0.7), and the XBMB3C (1.0.2) add-on (as well as all the skins) show incompatible. Any idea if there is an updated XBMB3C add-on, or should I be using a previous version of OpenElec?
xnappo 1611 Posted July 16, 2014 Posted July 16, 2014 Very odd. @@im85288 - any ideas? OpenElec 4.0.7 is Gotham - but there must be something in our repo config triggering this? xnappo
vidkun 10 Posted July 17, 2014 Author Posted July 17, 2014 Are you grabbing the XBMB3C add-on from the repo linked in the OP? Or are you grabbing it from outside the repo and trying to install from zip?
im85288 1493 Posted July 17, 2014 Posted July 17, 2014 Very odd. @@im85288 - any ideas? OpenElec 4.0.7 is Gotham - but there must be something in our repo config triggering this? xnappo No idea really, working fine here on OpenElec 4.0.7 The only way it should say incompatible is if it is on a Frodo version of XBMC...
ripper 5 Posted July 17, 2014 Posted July 17, 2014 Are you grabbing the XBMB3C add-on from the repo linked in the OP? Or are you grabbing it from outside the repo and trying to install from zip? I got it from the link in the OP. Oddly enough, I installed 4.0.6 last night and it was doing the same thing. After I let it sit for about 15 minutes, letting it install and update packages, all of the XBMB3C add-ons no longer showed incompatible. Everything is working great now. Haven't updated to 4.0.7 yet, but I assume there would be no issues. Thanks, all. And sorry for the apparent false alarm.
salphonso 4 Posted September 21, 2014 Posted September 21, 2014 First off, thanks for this quick and dirty guide. I was able to get XBMB3C on OpenELEC up and running. I have 1 main problem though. It will not play my media. I have everything already transcoded into an mp4 format. I can access my guide and live TV perfectly fine via Ethernet or WiFi but when I go to my movies and click to play one it sits for a minute and says working then just stops and never loads the movie. All my media is stored on a Synology NAS and I even tried giving NFS permission via the NAS just to make sure but still no luck. Before I tried OpenELEC I had Win 7 Pro on the device and XBMB3C loaded up through Windows. I was able to access everything without any problems. Any ideas on what could be causing this issue in Open ELEC?
salphonso 4 Posted September 21, 2014 Posted September 21, 2014 Here are the log files from the OpenELEC/XBMB3C test box. Do you need any from the MB3 server? log-2014-09-21-21.33.18.zip
salphonso 4 Posted September 21, 2014 Posted September 21, 2014 Did some more searching into the OpenELEC files and found in the Userdata\addon_data\plugin.video.xbmb3c. The setting.xml file had the <setting id="playFromStream" value="true" /> set to false. Set this to True and it fixed the issue and its working perfect now. 1
bluc 21 Posted April 11, 2015 Posted April 11, 2015 Did some more searching into the OpenELEC files and found in the Userdata\addon_data\plugin.video.xbmb3c. The setting.xml file had the <setting id="playFromStream" value="true" /> set to false. Set this to True and it fixed the issue and its working perfect now. Thanks for this have been searching for ages to find this solution. Works great now thanks again!!
xnappo 1611 Posted April 11, 2015 Posted April 11, 2015 Are you guys talking about the new addon or the old one? This was in the old addon settings options all along..
bluc 21 Posted April 11, 2015 Posted April 11, 2015 Yea old one in process of installing the new addon again atm could not get it to play anything last night.
