Library scan fails
Thanks for the feedback !
wp.rauchholz
On 5/29/2020 at 6:57 PM, mastrmind11 said:
And I'm assuming movies1 is accessible?  if so, the dot is likely your issue, there is an ACL assigned to the folder that might be overriding your actual permissions.  https://stackoverflow.com/questions/30594871/what-does-the-dot-at-the-end-of-the-permissions-in-the-output-of-ls-lah-mean
The hint with ACL made the trick. I removed the ACLs and scanning worked find again.
What I do not understand why the ACLs kicked in. selinux is disabled on my server.
Wolfgang
Thanks for the feedback.
