axxe 1 Posted May 14, 2020 Posted May 14, 2020 Hi, I have set up a library with automatic conversion, so that new files recorded from a HDHomeRun network tuner (UK Terrestrial Broadcast) are converted to the TV profile. this has been working OK for a while, but I am now getting failures. The log file is attached, but to me untrained eye it looks like this could be the problem: ~~~ 16:52:29.271 [matroska @ 0x2148900] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly16:52:29.531 frame= 183 fps= 21 q=-1.0 size= 3415kB time=00:00:08.58 bitrate=3273.6kbits/s throttle=off speed=0.996x 16:52:29.785 [matroska @ 0x2148900] Can't write packet with unknown timestamp ~~~ I also tried a manual conversion to the "mobile" format and that failed similarly. Any ideas whether this is actually the problem, or what I can do about it? ffmpeg-remux-63caa157-ecc6-43b0-9728-e00fab71a435_1.txt
axxe 1 Posted May 15, 2020 Author Posted May 15, 2020 My mistake, it looks like this is limited to the .mkv format. .mp4/h264 conversions seem to work OK.
softworkz 5129 Posted May 23, 2020 Posted May 23, 2020 @@axxe - This will be improved in the future. Right now, choosing mp4 as container is the best choice.
