FordGT90Concept 103 Posted May 14, 2020 Posted May 14, 2020 Title pretty much says it. If you select Guide then go down into the guide proper, you can't get back up, for example, to select Series. I tried reinstalling Emby and the issue persists.
Luke 42241 Posted May 14, 2020 Posted May 14, 2020 An update is going out to resolve it. Thanks for reporting. 1
FordGT90Concept 103 Posted May 17, 2020 Author Posted May 17, 2020 It doesn't appear to be fixed as of a few hours ago. I made sure Emby had no pending updates.
Solution Luke 42241 Posted May 17, 2020 Solution Posted May 17, 2020 We'll be pushing an update to the store. Thanks. 1
