Mkilbride 86 Posted May 13, 2020 Posted May 13, 2020 So I have a NVIDIA Shield. For reference, this is the media information: It has two tracks. English and Japanese. My default audio is English. In Browser, it plays properly. Both audio tracks. However, on my NVIDIA Shield, I only get English audio. Regardless of which track I select...and the file is Direct Playing. I'm curious as to what is going on? No combination on my NVIDIA SHield(Android TV), got it to play anything but English.
sephrat 16 Posted May 13, 2020 Posted May 13, 2020 (edited) Sounds a lot like the issue I had here: https://emby.media/community/index.php?/topic/79619-tv-1758g-audio-choice-suddenly-not-taken-into-account/page-2 Probably a bug related to the weird audio codec. What Android TV app version are you running? Edited May 13, 2020 by sephrat
ebr 16338 Posted May 13, 2020 Posted May 13, 2020 If you force it to transcode, do the track selections work?
Mkilbride 86 Posted May 14, 2020 Author Posted May 14, 2020 Yeah. If I transcode, it works. I tried it in Jellyfin; it direct played correctly. Same with Plex.
ebr 16338 Posted May 14, 2020 Posted May 14, 2020 Can you please play this item for just a few seconds, try to switch tracks and then stop and send the log from the app? Thanks.
ebr 16338 Posted May 14, 2020 Posted May 14, 2020 Or, if you could PM me a link to this exact media file, I can investigate it myself. Thanks.
ebr 16338 Posted May 15, 2020 Posted May 15, 2020 Okay, I was able to get your sample (thanks) and this should be fixed in the next release/beta. Thanks. 1
