shdwkeeper 15 Posted May 12, 2020 Posted May 12, 2020 Is there a way to configure the guide to play the show directly from the guide without a popup screen asking you to hit play? Seems like an unnecessary step, if I see the show i want to play on the guide I should click it and its starts playing, instead an additional screen asking you to hit play. If I want to know more about the show I should hit an info button or something. 1 1
kanipek 230 Posted May 12, 2020 Posted May 12, 2020 You can do this by using the play button on your remote or your keyboard. Sent from my SM-N900T using Tapatalk
shdwkeeper 15 Posted May 13, 2020 Author Posted May 13, 2020 (edited) How about an ipad or mobile device? Just clicking the show on the guide doesn't work than huh? You have to select it an hit play button on fire or shield remote? Edited May 13, 2020 by shdwkeeper
kanipek 230 Posted May 13, 2020 Posted May 13, 2020 I can't speak to apple devices. But on my Android phones/tablets it is as you describe - touch the EPG program then select Play in the pop-up window. As far as using a remote or keyboard yes scrolling to the EPG program I would like to watch using the remote/keyboard then hitting the Play button to begin play using the web app, Fire TV and the Android TV app.
rechigo 367 Posted May 13, 2020 Posted May 13, 2020 IMO right clicking a cell in the guide should give you a context menu containing the options you'd see if you brought up the dialog by left clicking Sent from my Galaxy S10
shdwkeeper 15 Posted May 13, 2020 Author Posted May 13, 2020 I want to use my remote on the shield and just click on the program in the guide and have it start playing the live tv program. As of now I have to find the play button and press that, why can we make it so the main button launches the show.
arrbee99 1836 Posted May 13, 2020 Posted May 13, 2020 I want to use my remote on the shield and just click on the program in the guide and have it start playing the live tv program. As of now I have to find the play button and press that, why can we make it so the main button launches the show. I would politely beg to differ. I reckon its best for it to take you to the details screen. I'm not near my Shield at the moment, but I think if you go to the programs detail page the default from there is Play anyway. Also its consistent, you go to the details screen for other not currently playing programs so this should be the same. In Theater it used to do what you would like, and to me it was quite annoying, starting stuff I didn't want. And the details screen is just that, a chance to look at details so you can decide whether to bother or not. 1
Spaceboy 2573 Posted May 13, 2020 Posted May 13, 2020 I want to use my remote on the shield and just click on the program in the guide and have it start playing the live tv program. As of now I have to find the play button and press that, why can we make it so the main button launches the show.because we want options like being able to see the program description or set a recording. If you want to play hit play
shdwkeeper 15 Posted May 13, 2020 Author Posted May 13, 2020 (edited) I would politely beg to differ. I reckon its best for it to take you to the details screen. I'm not near my Shield at the moment, but I think if you go to the programs detail page the default from there is Play anyway. Also its consistent, you go to the details screen for other not currently playing programs so this should be the same. In Theater it used to do what you would like, and to me it was quite annoying, starting stuff I didn't want. And the details screen is just that, a chance to look at details so you can decide whether to bother or not. I'm just used to Directv, highlight ABC hit select and it plays, if I want info, I select info. When using my Vizio remote with my Shield I can type in the channel number and it takes me to the channel in the guide, but the remote doesn't have a seperate play button, its a combo Select/Play/Pause button. Anyway it would be a great option that you can turn on and off. Channels DVR plays right away, when you long press on the select button than your options come up to select record or season pass, etc, and the show plays in 2-3 secs. No way can I get Emby to play that fast. Edited May 13, 2020 by shdwkeeper
shdwkeeper 15 Posted May 13, 2020 Author Posted May 13, 2020 (edited) because we want options like being able to see the program description or set a recording. If you want to play hit play That's what the long press on the button is for to bring up the options. Edited May 13, 2020 by shdwkeeper
Spaceboy 2573 Posted May 13, 2020 Posted May 13, 2020 That's what the long press on the button is for to bring up the options.how slow is your device? I can double click ok in less than 0.5s and have the stream playing immediately. It’s one very quick additional ok. But I also have a play button
shdwkeeper 15 Posted May 13, 2020 Author Posted May 13, 2020 how slow is your device? I can double click ok in less than 0.5s and have the stream playing immediately. It’s one very quick additional ok. But I also have a play button I have emby server installed on a Qnap TVS-662n and I'm running the client on a Shield. Its decent equipment. Stream definitely doesn't play immediately, emby and plex take longer to play than Channels DVR.
arrbee99 1836 Posted May 13, 2020 Posted May 13, 2020 how slow is your device? I can double click ok in less than 0.5s and have the stream playing immediately. It’s one very quick additional ok. But I also have a play button I know you mentioned in another thread (where sub3 replied) your tv stuff starts quick, but you're talking about from your server (using a plugin I think ) to a Shield ? Thats impressive. Is that with a tuner or iptv ?
arrbee99 1836 Posted May 13, 2020 Posted May 13, 2020 I want to use my remote on the shield and just click on the program in the guide and have it start playing the live tv program. As of now I have to find the play button and press that, why can we make it so the main button launches the show. Just found out Play on the (older) Shield remote is double tap on the volume slider
shdwkeeper 15 Posted May 13, 2020 Author Posted May 13, 2020 I know you mentioned in another thread (where sub3 replied) your tv stuff starts quick, but you're talking about from your server (using a plugin I think ) to a Shield ? Thats impressive. Is that with a tuner or iptv ? I highly doubt his shows are playing in .5secs
Spaceboy 2573 Posted May 13, 2020 Posted May 13, 2020 I highly doubt his shows are playing in .5secsthe 0.5s was to double tap ok.
shdwkeeper 15 Posted May 13, 2020 Author Posted May 13, 2020 the 0.5s was to double tap ok. You said your stream is playing immediately, mine buffers for a few seconds than starts playing, much slower than Channels, but about the same time as Plex.
Spaceboy 2573 Posted May 14, 2020 Posted May 14, 2020 You said your stream is playing immediately, mine buffers for a few seconds than starts playing, much slower than Channels, but about the same time as Plex.as I say the 0.5s was in reference to pressing ok twice and getting the buffering started, if you want to call it that. Depending on what your stream is I’d say they do start immediately. For iptv channels for example, it would be too quick to time. Less than a second
ebr 16309 Posted May 14, 2020 Posted May 14, 2020 My live TV also starts in under a second but this depends on if ffmpeg has to be involved at all. In my case, it usually doesn't.
Pkanarki 2 Posted May 14, 2020 Posted May 14, 2020 My livetv ip streams used to take 3-5 seconds before they started. But when i got new router they start almost instantly, less than a second. So in my case I am sure the router was to blame, it was a old cheap tp link with custom ddwrt firmware. The new router is linksys wrt1200ac also with ddwrt firmware.
shdwkeeper 15 Posted May 14, 2020 Author Posted May 14, 2020 Mine is probably taking longer because I'm playing from a NAS I'm sure.
shdwkeeper 15 Posted May 14, 2020 Author Posted May 14, 2020 Actually when I have the setting on Direct stream Live TV is plays much faster. But we want to be able to pause Live TV so we disable that. So it takes longer to get the playback going, is that what everyone else is experiencing also?
kanipek 230 Posted May 14, 2020 Posted May 14, 2020 Actually when I have the setting on Direct stream Live TV is plays much faster. But we want to be able to pause Live TV so we disable that. So it takes longer to get the playback going, is that what everyone else is experiencing also? That is typical in my experience
Spaceboy 2573 Posted May 14, 2020 Posted May 14, 2020 Actually when I have the setting on Direct stream Live TV is plays much faster. But we want to be able to pause Live TV so we disable that. So it takes longer to get the playback going, is that what everyone else is experiencing also?absolutely, but I take the opposite approach. I always direct play and flip to transcoding on the rare occasions I want to pause
paychi 4 Posted December 22, 2020 Posted December 22, 2020 Hello, I have Xiaomi Mi Tv Box S which does not have play button on remote at all. And this play/record popup really annoys me. If there could be setting for this in the app, it would be really great... 1
