tlkounev 14 Posted May 11, 2020 Posted May 11, 2020 Hi, I installed new client 1.0.78 on my UE65RU7022KXXH and now every DTS track isnt transcode anymore. Every movie with DTS is direct playing with DTS which client cant play coz known problem with Samsung TV(doesnt support DTS) and client finishing playing with msg "Playback Error No compatible streams are currently available. Please....". Přímé přehrávání means direct playing... I have allowed playing movies which needs trancode. I dont have emby premiere anymore... Now I need to pay for Premier or is this bug? Thx tlk embyserver.txt ffmpeg-transcode-1e5a75a4-4205-49af-87c9-ae33c15e4fc0_1.txt ffmpeg-transcode-7c1ef408-e6dd-49aa-807e-ed985a63b2bc_1.txt ffmpeg-transcode-8e7d9de2-2675-4863-afc8-907adade1448_1.txt ffmpeg-transcode-46e5ad0b-5494-4c46-8532-750696871b17_1.txt ffmpeg-transcode-0372afe3-b1a1-4e93-898e-12d8a3be1655_1.txt ffmpeg-transcode-389bcb9c-8ac1-4cdd-bb54-e738e9c03acd_1.txt ffmpeg-transcode-480e112d-8dda-46f0-8f7a-21fe52f60749_1.txt
FrostByte 5453 Posted May 11, 2020 Posted May 11, 2020 It's working for me with "Allow audio playback that requires transcoding" turned on so I don't there's a bug. I believe all transcoding requires Premiere, but @@Luke would need to confirm because I'm not sure.
Happy2Play 9811 Posted May 11, 2020 Posted May 11, 2020 (edited) But according to the logs it is transcoding 21:56:42.568 Stream mapping: 21:56:42.568 Stream #0:0 (hevc) -> format (graph 0) 21:56:42.568 subtitles (graph 0) -> Stream #0:0 (libx264) 21:56:42.569 Stream #0:3 -> #0:1 (dts (dca) -> ac3 (native)) Unless something recently changed only Hardware Acceleration requires Premiere from a transcoding standpoint. Edited May 11, 2020 by Happy2Play 1
FrostByte 5453 Posted May 11, 2020 Posted May 11, 2020 It shouldn't even have to transcode just for DTS - AC3 conversion. Mine is direct streaming according to SFN and the dashboard Here's my log https://pastebin.com/CqYb74G2
Luke 42242 Posted May 12, 2020 Posted May 12, 2020 Can you try disabling subtitles prior to playback? Please see how that compares. Thanks.
tlkounev 14 Posted May 12, 2020 Author Posted May 12, 2020 Yes, it helped. I disabled sub before playing movie and it started. Tried enable sub again during video was playing and it crash. embyserver.txt ffmpeg-remux-1ddaca8a-033d-4443-938d-a98a94e47bc0_1.txt ffmpeg-remux-dd1f16fd-4e13-41f3-a6ca-23bcca42b1d6_1.txt ffmpeg-transcode-6a3031ba-296e-43af-ba38-74f6887b9f2d_1.txt
Happy2Play 9811 Posted May 12, 2020 Posted May 12, 2020 What hardware is Emby installed on? It would appear to choke on the transcode/subtitle burn in. The server can not convert the media fast enough. 01:58:19.345 Stream mapping:01:58:19.345 Stream #0:0 (h264) -> subtitles (graph 0)01:58:19.346 subtitles (graph 0) -> Stream #0:0 (libx264)01:58:19.346 Stream #0:1 -> #0:1 (dts (dca) -> ac3 (native)) 02:00:16.500 frame= 1113 fps=9.5 q=20.0 size= 22520kB time=00:00:46.52 bitrate=3978.7kbits/s throttle=off speed=0.396x @@softworkz what are all these Playback position unknown? >> ThrottleByStreamBufferSize: Playback position unknown
softworkz 5133 Posted May 12, 2020 Posted May 12, 2020 @@softworkz what are all these Playback position unknown? >> ThrottleByStreamBufferSize: Playback position unknown That means that the client hasn't reported its playback position to the server.
tlkounev 14 Posted May 12, 2020 Author Posted May 12, 2020 I have Emby server running on Synology DS216+II(8GB RAM). It has enough power transcoding 4K/1080p(H244, H245). Mostly I have movies in MKV container with DTS track and SRT/SUB subtitles and sometimes I have subtitles separately downloaded with opensubtitles module. In past I didnt have problems transcode anything. You can see there isnt problem transcode movie with DTS-HD MA 7.1 and sub enabled when Im using Chrome.
