mrjn 0 Posted May 9, 2020 Posted May 9, 2020 Hi !I'm trying the emby solution to setup a server media. I use my personnal computer (i7-7700k, 16Go ram, no graphic card) to direct play on my mibox 4s. My computer is wired to my internet box and the mibox uses wifi. They are really near as the mibox is over the internet box. I hade a few lag issue tonight. It was like 4 seconds freeze (looks like it was not buffering or doing something : no loading wheel) Checked for the logs, hope it's the good ones. Don't know why one was about transcode... I disabled it I believe. The media played was : General Unique ID : Complete name : Format : Matroska Format version : Version 4 File size : 23.7 GiB Duration : 2 h 8 min Overall bit rate mode : Variable Overall bit rate : 26.3 Mb/s Movie name : Kingsman: The Secret Service (2014) Encoded date : UTC 2020-04-26 18:02:03 Writing application : mkvmerge v43.0.0 ('The Quartermaster') 64-bit Writing library : libebml v1.3.10 + libmatroska v1.5.2 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 8 min Bit rate : 21.3 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.107 Stream size : 19.1 GiB (81%) Writing library : x265 3.3+2-gd9a7411cc:[Windows][MSVC 1925][64 bit] 10bit Encoding settings : cpuid=1111039 / frame-threads=4 / numa-pools=24 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=185200 / level-idc=51 / high-tier=1 / uhd-bd=1 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=1 / keyint=24 / gop-lookahead=0 / bframes=8 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=80 / lookahead-slices=6 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=4 / selective-sao=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=18.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=3 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1) / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.01 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0 Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Audio ID : 2 Format : DTS ES XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Codec ID : A_DTS Duration : 2 h 8 min Bit rate mode : Variable Bit rate : 4 935 kb/s Channel(s) : 8 channels Channel layout : C L R Ls Rs LFE Lb Rb Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossless Stream size : 4.44 GiB (19%) Title : DTS-HD Master Audio / 7.1 / 48 kHz / 4935 kbps / 24-bit Language : English Default : Yes Forced : No Text #1 ID : 3 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 40 min Bit rate : 128 b/s Count of elements : 38 Stream size : 95.0 KiB (0%) Title : Forced only Language : English Default : Yes Forced : No Not sure if it helps. I used subtitles (not sur it was thoses ones, there where a lot on the description files and I cut it out to have a clearer post. It worked crystal clear with Avatar, don't know what happened. Anyway, the app looks great, thanks for your work. embyserver.txt embyserver-63724665599.txt hardware_detection-63724638513.txt ffmpeg-transcode-b8e64e32-35d5-4e3f-8474-d6edf9263094_1.txt
ebr 16338 Posted May 10, 2020 Posted May 10, 2020 Hi. It looks like you are burning in graphic subs in a 4K HEVC file. All of that adds up to significant processing power being needed on the server. The reason the transcoding/burn-in was needed is due to the combination of graphic subs and an audio format that is not supported by the Mi (DTS-HD MA). Either obtaining a version with a compatible audio track or obtaining text-based subtitles would probably eliminate your problem here.
mrjn 0 Posted May 10, 2020 Author Posted May 10, 2020 oh ok, kind of good for me ! I believed it was my network failing. Will work on the subtitles stuff and choose more carefully the audio format ! Thanks for your answer, will keep you updated !
