Ondsky 0 Posted May 9, 2020 Posted May 9, 2020 Hallo I just went over to emby from plex and I am loving it. But I have a problem with Live tv and iptv plugin I have loaded a m3u file in live tv. the channel coms up, but it wont load the channel. it stops after a few sec and says "No compatible streams are currently available. Please try again later or contact your system administrator for details." the problem is that it’s a free Danish channel and the m3u works fine in vlc and win media player I have also tried to put the m3u lines in IPTV with same results. the line I have tested "https://dr01-lh.akamaihd.net/i/live/dr01_0@147054/index_3000_av-p.m3u8" I have also tried changing the m3u8 to ts as suggested in another forum post without any effect. I have been looking at the forum all day for a solution. can anyone help an old guy out ? Btw this is what is in my m3u file #EXTM3U#EXTINF:0,DR1https://dr01-lh.akamaihd.net/i/live/dr01_0@147054/index_3000_av-p.m3u8#EXTINF:0,DR2https://dr02-lh.akamaihd.net/i/live/dr02_0@147055/index_3000_av-p.m3u8#EXTINF:0,TV ØSThttp://cdn-lt-live.tveast.dk/dc-0/live/hls/p/1953381/e/0_zphj9q61/sd/10000/t/5V0e8WiEDy1T0USo0Guueg/index-s32.m3u8#EXTINF:0,TV2 Lorryhttp://cdn-lt-hls-vod.tv2lorry.dk/fhls/p/2045321/sp/204532100/serveFlavor/entryId/0_0u9letdh/v/1/flavorId/0_p5f7q6yf/name/a.mp4/index.m3u8
Luke 42244 Posted May 9, 2020 Posted May 9, 2020 Hi there, let's look at an example. Please attach the information requested in how to report a problem: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
Ondsky 0 Posted May 9, 2020 Author Posted May 9, 2020 Hi there, let's look at an example. Please attach the information requested in how to report a problem: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks. you just want me to post logfile ? other than that I think I have explained myself OK if not please say so. embyserver.txt
Ondsky 0 Posted May 10, 2020 Author Posted May 10, 2020 Hi Luke I have no idea if its running on a ducker container. my emby is running on a paid server. can I see if it is somewhere in the emby setup ?
