Mkilbride 86 Posted May 9, 2020 Posted May 9, 2020 So basically this. I have TV Shows, Movies, and Anime libraries. For anime; I'd prefer to set the default to Japanese with Subtitles. For movies, English and no subs unless forced. For TV Shows, the same. However, Emby only allows one overall setting this for this, for all libraries, instead of just one. I think it'd be a pretty nice little feature. 19 14
Luke 42243 Posted May 9, 2020 Posted May 9, 2020 Hi, yes this has come up before. It's possible for the future. Thanks for the feedback. 1 1
Happy2Play 9811 Posted May 9, 2020 Posted May 9, 2020 Am I missing something as there are already per library setting for "Preferred metadata download language", "Preferred image download language" and subtitles? So we have Global which uses your Emby language, per library, and per item.
Luke 42243 Posted May 9, 2020 Posted May 9, 2020 I think he's referring to the user audio and subtitle preferences.
Mkilbride 86 Posted May 9, 2020 Author Posted May 9, 2020 I think he's referring to the user audio and subtitle preferences. I am 1
Baja 4 Posted May 21, 2020 Posted May 21, 2020 +1 for this request. My wife and I have different preferences for subtitles. We are currently using multiple user profiles as a workaround, but a per library option would be even better.
ebr 16335 Posted May 22, 2020 Posted May 22, 2020 +1 for this request. My wife and I have different preferences for subtitles. We are currently using multiple user profiles as a workaround, but a per library option would be even better. Hi. That isn't really a work-around. That is exactly as designed - we have the ability for different users to have different preferences.
Baja 4 Posted May 22, 2020 Posted May 22, 2020 Hi. That isn't really a work-around. That is exactly as designed - we have the ability for different users to have different preferences. To clarify, different users for each library is the workaround. E.g. Wife1 = Library1 (subtitles on), Wife2 = Library2 (subtitles off), etc OP's request would allow us to stop swapping profiles for the same user.
HSWMKHSWMK 0 Posted May 6, 2021 Posted May 6, 2021 Hello, How this feature going ? Is it implemented ? Thanks
dieter3k 0 Posted January 4, 2022 Posted January 4, 2022 Bump. I'd like this feature, as I am watching TV shows differently from movies.
Kosmik 0 Posted April 18, 2022 Posted April 18, 2022 My anime is subbed and sometimes I have dubbed dual audio and prefer original with subs.Subsxworks fine but I have to switch audio every episode, would love this feature.
Mkilbride 86 Posted April 20, 2022 Author Posted April 20, 2022 Yeah I sure would fall in love with this feature. Same with per show. i.e, "Select Audio track for Show: Japanese" "Select Subtitle for Show: English(Dialogue)" 1
Locutus64 125 Posted April 20, 2022 Posted April 20, 2022 On 5/9/2020 at 6:22 AM, Mkilbride said: So basically this. I have TV Shows, Movies, and Anime libraries. For anime; I'd prefer to set the default to Japanese with Subtitles. For movies, English and no subs unless forced. For TV Shows, the same. However, Emby only allows one overall setting this for this, for all libraries, instead of just one. I'll give this a up vote. I would never use it cause I don't have a need for it, but PLENTY of people do have a need for it.
point5pnoi 0 Posted May 10, 2022 Posted May 10, 2022 I'll cast my vote as well. Per library would be very beneficial instead of having to switch audio tracks every episode.
IamGimli 0 Posted October 18, 2022 Posted October 18, 2022 On 20/04/2022 at 00:33, Mkilbride said: Yeah I sure would fall in love with this feature. Same with per show. i.e, "Select Audio track for Show: Japanese" "Select Subtitle for Show: English(Dialogue)" Also the ability to download an extra language for subtitles per show (similar to the way it works on a per episode basis) would be great.
amateurgod 33 Posted January 31, 2023 Posted January 31, 2023 +1 for this and for being able to set audio/subs per show rather than just per episode
heciruam 30 Posted January 31, 2023 Posted January 31, 2023 I'd prefer it I if there was the option of setting default audio language depending on the origin of country rather than it being library specific.
DemonI 5 Posted February 14, 2023 Posted February 14, 2023 +1 for this from me as well. Just turning subs on for each One Piece episode alone is an insane task without a library-wide setting. 1
