Mkilbride 86 Posted May 9, 2020 Posted May 9, 2020 In the case of .hack :Folder: https://i.imgur.com/5tMcFSi.pngEpisodes: https://i.imgur.com/dO3nZKd.pngEmby: https://i.imgur.com/n3a9ZoE.pngIt shows up, but no episodes. In it's own folder it worked fine. But why not as part of the season? It shows up in Plex.
Solution Happy2Play 9802 Posted May 9, 2020 Solution Posted May 9, 2020 Best guess is they are ignored do to the fact they start with periods. Emby has coding to ignore items with periods as it is problematic on NAS and MacOS. 1
Mkilbride 86 Posted May 9, 2020 Author Posted May 9, 2020 Best guess is they are ignored do to the fact they start with periods. Emby has coding to ignore items with periods as it is problematic on NAS and MacOS. That was a good guess. I actually thought something similar, but since it plays from it's own folder, I felt unsure before I went and renamed everything. Just did that...and it showed up. Thanks.
