saj 14 Posted May 8, 2020 Posted May 8, 2020 Hi, Would it be possible for Emby to supply more days of guide data? EPG123 allows one to request up to 21 days of data from Schedules Direct. Currently, it appears that Schedules Direct is only supplying 17 days of data, at least in the U.S. Emby seems to only supply 14 days at most. It would be nice to have as many days as Schedules Direct will supply or to give us an option as to how many days we want. Thank you for your consideration.
Chris442 3 Posted September 16, 2020 Posted September 16, 2020 I only am seeing 7 days in my guide. Is there a setting that extends it to the full 14 days?
vdatanet 1619 Posted September 16, 2020 Posted September 16, 2020 21 minutes ago, Chris442 said: I only am seeing 7 days in my guide. Is there a setting that extends it to the full 14 days? In DVR setup, you can set the days: 1
Chris442 3 Posted September 16, 2020 Posted September 16, 2020 Thank you vdatanet! I overlooked that. Now I just need to see if the guide will refresh with the extra 7 days.
Carlo 4561 Posted September 16, 2020 Posted September 16, 2020 1 hour ago, Chris442 said: Thank you vdatanet! I overlooked that. Now I just need to see if the guide will refresh with the extra 7 days. It will. If you change it to 14 days you can then manually kick off the guide refresh.
sundevil67 30 Posted October 4, 2020 Posted October 4, 2020 I can't get more than a few hours; after that everything is blank. Is there any other option that might impact this?
Luke 42237 Posted October 5, 2020 Posted October 5, 2020 26 minutes ago, sundevil67 said: I can't get more than a few hours; after that everything is blank. Is there any other option that might impact this? What guide data are you using?
