DarrenClimie-Newman 6 Posted August 13, 2020 Author Posted August 13, 2020 On 8/8/2020 at 2:25 AM, Luke said: Can you use a file browser on qnap and see the full path to it? Yes QNAP file manager allows you to see the mounted paths in the File Explorer Tree, just doesn't appear where it was previously under a folder called /mnt, which would make sense as mnt is short for mount.
garegina 6 Posted August 13, 2020 Posted August 13, 2020 I don't know what the purpose of installing the codexpack is. I found the answer here but there is no reason on post as to why it shows the share.
