DarrenClimie-Newman 6 Posted May 8, 2020 Posted May 8, 2020 Hi All. Wonder if someone can help me please. I'm running Emby on my QNAP NAS, and I've had to move my movies (2TB worth) to my HP Server on the network, because I'm running out of storage on the NAS, and I've got 10TB available on my HP Server. I've tried to update the Movies Library i had set up, to use the new Network Location, but it won't find the movies. The HP Server is 192.168.1.35 The Network Share Path is \\HP-Server\HP Server Storage Disk (only 2 Folders here, Movies 2 and Music) In the library settings of Emby I've set: Folder: 192.168.1.35 (Optional) Shared Network Folder: HP Server Storage Disk\Movies 2 Its allows me to save the location, so assume the settings at valid. Is there anything else I need to do, or change a setting? Does it look right? Thanks Darren Sent from my SM-G970F using Tapatalk
DarrenClimie-Newman 6 Posted May 8, 2020 Author Posted May 8, 2020 Hi All. Wonder if someone can help me please. I'm running Emby on my QNAP NAS, and I've had to move my movies (2TB worth) to my HP Server on the network, because I'm running out of storage on the NAS, and I've got 10TB available on my HP Server. I've tried to update the Movies Library i had set up, to use the new Network Location, but it won't find the movies. The HP Server is 192.168.1.35 The Network Share Path is \\HP-Server\HP Server Storage Disk (only 2 Folders here, Movies 2 and Music) In the library settings of Emby I've set: Folder: 192.168.1.35 (Optional) Shared Network Folder: HP Server Storage Disk\Movies 2 Its allows me to save the location, so assume the settings at valid. Is there anything else I need to do, or change a setting? Does it look right? Thanks Darren Sent from my SM-G970F using Tapatalk Sent from my SM-G970F using Tapatalk
jillybean 2 Posted May 8, 2020 Posted May 8, 2020 (edited) Just did a test on my QNAP. I just entered the network folder location in the 'Folder' box ie \\10.0.0.75\Media\TV and this seemed to work ok. Did you try it this way? Edited May 8, 2020 by jillybean
DarrenClimie-Newman 6 Posted May 8, 2020 Author Posted May 8, 2020 I think I did try that, I think I've tried all combinations... I'll try again.... Sent from my SM-G970F using Tapatalk
DarrenClimie-Newman 6 Posted May 8, 2020 Author Posted May 8, 2020 (edited) Doesn't seem to like the full path in Folder.... Sent from my SM-G970F using Tapatalk Edited May 8, 2020 by DarrenClimie-Newman
DarrenClimie-Newman 6 Posted May 8, 2020 Author Posted May 8, 2020 Here the path so I know its correct... Sent from my SM-G970F using Tapatalk
jillybean 2 Posted May 8, 2020 Posted May 8, 2020 Sorry, can't really help as my test worked ok. Only other thing I can think of would be check permissions on the remote folder.
DarrenClimie-Newman 6 Posted May 8, 2020 Author Posted May 8, 2020 Permissions are full for all users.... Can I ask what version of Firmware are you running on your QNAP? Sent from my SM-G970F using Tapatalk
Luke 42241 Posted May 8, 2020 Posted May 8, 2020 What I would suggest instead is mounting the network path to a local path using the tools in the qnap os. Then add the new local path into emby instead. Please see if that helps. Thanks.
jillybean 2 Posted May 8, 2020 Posted May 8, 2020 I have QTS 4.4.2.1270 on my TS451+. The remote folder I added was one on another NAS on my network (Netgear readynas). I don't have anything 'windows' to test.
DarrenClimie-Newman 6 Posted May 8, 2020 Author Posted May 8, 2020 What I would suggest instead is mounting the network path to a local path using the tools in the qnap os. Then add the new local path into emby instead. Please see if that helps. Thanks.Hi I have mounted this Windows Share in QNAP Hybridmount, however, Emby doesn't seem to want to see mounted paths... Plex does however.... [emoji19] Sent from my SM-G970F using Tapatalk
DarrenClimie-Newman 6 Posted May 8, 2020 Author Posted May 8, 2020 I have QTS 4.4.2.1270 on my TS451+. The remote folder I added was one on another NAS on my network (Netgear readynas). I don't have anything 'windows' to test.Interestingly... I upgraded 1270 about 3 weeks ago, it broke loads of things including external and internal services, so I had to roll back. I'm not comfortable going to 1270 again, until QNAP bring the next FW release out. Sent from my SM-G970F using Tapatalk
Luke 42241 Posted May 9, 2020 Posted May 9, 2020 Have you checked the permissions of the mounted path?
DarrenClimie-Newman 6 Posted May 9, 2020 Author Posted May 9, 2020 Have you checked the permissions of the mounted path?Yes full permissions: Sent from my SM-G970F using Tapatalk
DarrenClimie-Newman 6 Posted May 12, 2020 Author Posted May 12, 2020 Anyone with any ideas on this?? I've tried all sorts of reference paths, and nothing seems to work.... :-( Sent from my SM-G970F using Tapatalk
Luke 42241 Posted July 9, 2020 Posted July 9, 2020 On 5/8/2020 at 6:36 PM, DarrenClimie-Newman said: Hi I have mounted this Windows Share in QNAP Hybridmount, however, Emby doesn't seem to want to see mounted paths... Plex does however.... Sent from my SM-G970F using Tapatalk What is the mounted path in QNAP? @PenkethBoy have you tried this?
garegina 6 Posted August 2, 2020 Posted August 2, 2020 Hi I am having the same issue - I have mounted my Win 10 shared folder using Remote Mount (Hybrid mount) and I have successfully mounted it but I don't know how to find its mounted path to add to emby - Can anyone help please Thanks Gary
DarrenClimie-Newman 6 Posted August 2, 2020 Author Posted August 2, 2020 (edited) Hi Gary So, I finally found the path using Plex (which I moved from), as it was able to see the path straight out the box. It was something like/ /mnt/rf/xxxxxxxxxxxxxxxx However, I rebuilt my network yesterday, and also updated my QNAP firmware to the release from a few days ago. It now doesnt find that location. Hybrid Mount in QNAP still mounts the same path on my Win10 machine, it just won't see it now. I wonder if the latest firmware has 'hidden' the Mounted path?? Edited August 2, 2020 by DarrenClimie-Newman
DarrenClimie-Newman 6 Posted August 7, 2020 Author Posted August 7, 2020 I'm getting the impression that the latest firmware update on QNAP hides the mounted path for Hybrid Mount.
Luke 42241 Posted August 8, 2020 Posted August 8, 2020 Can you use a file browser on qnap and see the full path to it?
garegina 6 Posted August 12, 2020 Posted August 12, 2020 Hi Darren I believe I may have found the answer. Check that you have CodexPack installed and if not - install it. I found my hybridmount in /share/CACHEDEV1_DATA/.qpkg/CodexPack/share/My Drone Videos. I successfully added that path to Emby. Let me know how you get on ?
Luke 42241 Posted August 13, 2020 Posted August 13, 2020 21 hours ago, garegina said: Hi Darren I believe I may have found the answer. Check that you have CodexPack installed and if not - install it. I found my hybridmount in /share/CACHEDEV1_DATA/.qpkg/CodexPack/share/My Drone Videos. I successfully added that path to Emby. Let me know how you get on ? Hi, what is the purpose of installing CodexPack ?
DarrenClimie-Newman 6 Posted August 13, 2020 Author Posted August 13, 2020 Hi. I don't need it now, I've increased my NAS Capacity and moved my files back to the NAS from a Windows box. I already have codexpack installed. That doesn't make any sense, as that app has no relation to HybridMount? Glad you got yours working.
