flipside 6 Posted May 6, 2020 Posted May 6, 2020 (edited) HI All Over the last week or so ive been having some playback issues on my mibox. Ive tried a number of options including factory restting the mibox and clearing up on the server removing plugins etc but its still slow and play back is very stop start, but works fine on the shield Ive attached a snapshot of my log from the time I last tested im hoping someone can point me in the right direction. Many Thanks EMBY server running on Synology NAS 412+ , old but is still only maxing out at around 80-90% mem and cpu when under load All devices are wired with a 1Gb connection from the NAS and 100Mb connection to the MiBox via a UGREEN ethernet-usb adapter Edited May 7, 2020 by flipside
Bart91106 2 Posted May 6, 2020 Posted May 6, 2020 Recently I had this issue. It wasn't my MiBox, but my internet. I reset vs restarting my internet and this solved the problem. I hope this helps. Sent from my Lenovo TB-8705F using Tapatalk
Sammy 791 Posted May 6, 2020 Posted May 6, 2020 What are the issues? Where's the log? Do you have screen shots?
flipside 6 Posted May 7, 2020 Author Posted May 7, 2020 Recently I had this issue. It wasn't my MiBox, but my internet. I reset vs restarting my internet and this solved the problem. I hope this helps. Sent from my Lenovo TB-8705F using Tapatalk Thank you and Ill give it a try but this is all local and runs find on the Shield
flipside 6 Posted May 7, 2020 Author Posted May 7, 2020 What are the issues? Where's the log? Do you have screen shots? What are the issues? Its very slow to start playing and playback freezes intermitantly making it pretty much unsuable Where's the log? Should have been attached as per my comment in the post but seems to have got lost in the ether, have added here Do you have screen shots? I can supply them but all we have is a spinning blue circle wait icon which wont give you much mibox_slow_log.txt
Luke 42246 Posted May 7, 2020 Posted May 7, 2020 Can you please attach the complete emby server log? if there was an ffmpeg log, please attach that as well. thanks.
Sammy 791 Posted May 7, 2020 Posted May 7, 2020 One thing to keep in mind with MiBox S is that you need to limit the streaming rate to 40mpbs. Anything over that will stutter. I just switched out a bunch of ShieldTV's for MiBox S' at a handsome profit but my server can handle the transcoding and only one of my 10 TV's is worth having a higher bit rate and that maybe is questionable as it is 1080p Panasonic Plasma (at my viewing distance, 4k isn't going to make a difference) and the AVR is the same era, both about 7 years old now. At any rate, I'm interested in seeing what's going on. You should enable logging in the MiBox too. Emby for Android TV/Fire TV and Emby for Roku Logs These apps have the option to send an app log to us electronically. You enter the settings page and turn on the "Debug Options". Now there will be a new tile on your home page settings row (or menu option on the user menu at the top) labelled "Send Log". Reproduce your problem and then use this button to send the log. Then add the following information to your report in the forum: Exactly what you were doing and what happened. Include the name of whatever you played if it is a playback problem The time you sent the log (in Eastern Time please - UTC -5) The name of the Emby user on the local server that was logged in at the time https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/
flipside 6 Posted May 7, 2020 Author Posted May 7, 2020 Can you please attach the complete emby server log? if there was an ffmpeg log, please attach that as well. thanks. ok ill re run tonight so its at least the close to the end of the log file for ease of access
flipside 6 Posted May 7, 2020 Author Posted May 7, 2020 (edited) One thing to keep in mind with MiBox S is that you need to limit the streaming rate to 40mpbs. Anything over that will stutter. I just switched out a bunch of ShieldTV's for MiBox S' at a handsome profit but my server can handle the transcoding and only one of my 10 TV's is worth having a higher bit rate and that maybe is questionable as it is 1080p Panasonic Plasma (at my viewing distance, 4k isn't going to make a difference) and the AVR is the same era, both about 7 years old now. At any rate, I'm interested in seeing what's going on. You should enable logging in the MiBox too. https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Cool i fire this off at the same time Oh and 10 TV's ... woah Edited May 7, 2020 by flipside
flipside 6 Posted May 7, 2020 Author Posted May 7, 2020 (edited) Exactly what you were doing and what happened. Include the name of whatever you played if it is a playback problem - Trying to play Red Dwarf s9:e2 - Back to Earth. File took around 20 seconds to open and then froze after 4-5 secons of playback, started again and then froze The time you sent the log (in Eastern Time please - UTC -5) - 13:25 The name of the Emby user on the local server that was logged in at the time - embysvr emby server log.txt emby server ffmeg log.txt Edited May 7, 2020 by flipside 1
Sammy 791 Posted May 7, 2020 Posted May 7, 2020 (edited) Cool i fire this off at the same time Oh and 10 TV's ... woah I had 11 but my Daughter's, now out of the picture, ex sold one of them while he was living here without talking to me. To keep the peace I finally had to let it go but I'm still pissed! Edited May 7, 2020 by Sammy 1
ebr 16338 Posted May 7, 2020 Posted May 7, 2020 Hi. That isn't an ffmpeg log. That is a server log. Was there an ffmpeg log? Based on the activity in the server log, there should have been an ffmpeg log as well. Also, the app log you sent did not contain any playback. Did you send the log immediately after that playback attempt?
flipside 6 Posted May 9, 2020 Author Posted May 9, 2020 sorry all ill come back to this later , have some intersting times at home as my sons got a high temp and my wifes shielded
