ptlh2a 3 Posted May 6, 2020 Posted May 6, 2020 Good morning. First off, please forgive some of my ignorance with Emby - I came over from Plex, and like this product, but not an expert at it. Main (only issue I have had so far) issue is LiveTV streaming stops around 35 minutes after it starts.System: Ubuntu 18.04/small Dell desktop (quad core/8Gb/SSD), Hauppauge WinTV dual tuner (USB). NAS attached via external network mounts. LiveTV gets stored local on SSD. Using M3U tuner --> TVHeadend on same server. Running 4.4.2.0 for Emby version. LiveTV starts great, and runs flawlessly onto any device (but in the instance with provided logs, it was a Roku Ultra). In the attached logs, at 7:34, the wheels come off the wagon and the stream stops and reports "No Streams Available". I try to use iPad to open stream, and it just spins with no connection. TVHeadend does not show any stream establishing (it does when LiveTV is working). Restarting the Emby service fixes the issue, and LiveTV works again. Until it fails again. If I watch directly on TVHeadend, or set up a stream with VLC, it runs all day long, so it seems that it's something between TVHeadend and Emby. Really like this product more than Plex...was hoping this would work. From reading, this could be an existing bug that folks are working on. Attached is embyserver.txt log (not at debug setting - can repeat issue with debugging turned on if needed). It also could be some ham-fisted newbie mistake on my end, so any help is appreciated. FFMPEG file to Roku also added. Thanks for any help. Pete embyserver.txt ffmpeg-directstream-9830be88-b805-4551-a6b1-8f83a26fecff_1.txt
Luke 42244 Posted May 9, 2020 Posted May 9, 2020 Hi there, as a test, if you lower the in-app quality setting on the Roku so that the server does a full video transcode, does that resolve the issue?
ptlh2a 3 Posted May 12, 2020 Author Posted May 12, 2020 Good morning. I lowered the Roku app settings to 720HD/10Mb (it was set to Auto before), and also said to Allow Live Stream, and still ran into the same issue.Let me know if I need to run this test with debugging on for logging (or other additional steps). I appreciate the help. Thanks.Pete
ebr 16337 Posted May 12, 2020 Posted May 12, 2020 Hi. Did that cause a full transcode? Can we please see the ffmpeg log from that test?
ptlh2a 3 Posted May 12, 2020 Author Posted May 12, 2020 Oops - sorry. Should have posted it. Here it is. ffmpeg-transcode-20200511.txt
ptlh2a 3 Posted May 12, 2020 Author Posted May 12, 2020 So, I went thru the logs and saw a quit in there...let me re-run this until it completely fails.I will run it again and capture the log, and run it in debug mode as well, so please stand by. Pete
ptlh2a 3 Posted May 13, 2020 Author Posted May 13, 2020 Here is the FFMPEG log from a failure, with debugging option turned on. Thanks.Pete ffmpeg-transcode-20200513.txt
ptlh2a 3 Posted May 13, 2020 Author Posted May 13, 2020 Just for giggles, I took and ran the same test on an LG Smart TV (Emby Theatre App 1.0.24). Ran for about 40ish minutes, and ended with the same error "Playback Error. No compatible streams are currently available".When I try to connect to another channel (or that one), just get the same spinning circle like it's trying to connect. TVHeadEnd does not show any streams in it's UI (it does when Emby is running LiveTV ok). I was looking at logs, and some say "Server Returned 404 Not Found" and HTTP error 404 not found. I have attached one of those logs in this post.
ptlh2a 3 Posted May 13, 2020 Author Posted May 13, 2020 Oops...didn't click on "attach file". Here it is. ffmpeg-directstream-404 Example.txt
ptlh2a 3 Posted May 21, 2020 Author Posted May 21, 2020 Yes, with multiple devices (see above posts - tried on a different device).
Luke 42244 Posted June 16, 2020 Posted June 16, 2020 Hi, is it possible you're running out of disk space when this happens?
ptlh2a 3 Posted June 16, 2020 Author Posted June 16, 2020 I can run LiveTV and monitor disk space while it's running. I don't think it is, but I cannot say with full certainty. I can test and find out.
ptlh2a 3 Posted June 16, 2020 Author Posted June 16, 2020 I ran a show and kept watching the disk, and it did not decrease in disk space available. There is 80Gb on /dev/sda1 to work with. All slices on the server have plenty of space on them. I stopped the show I was watching, and then tried to get into another one, and it would not let me get into that show (just gave me the spinning disk like its attempting to, but nothing else). I really don't believe that disk space is an issue with this server. Any other thoughts? Thx.
ptlh2a 3 Posted June 17, 2020 Author Posted June 17, 2020 I just verified that disk space is not an issue - I watched a high-def program until it quit working, and the disk had dropped about 1.5Gb from the 80Gb available, and then returned to 80Gb after it stopped the program. Attempting to continue playing the program resulted in the same spinning disk but not establishing a stream thru TVHeadend, or beginning the program unless I restarted the Emby server (service only - not full reboot). Also, I performed the upgrade to 4.4.3.0, just in case it might help. Same results...the upgrade did not help this situation. Thanks. Pete
Carlo 4561 Posted June 26, 2020 Posted June 26, 2020 @ptlh2a check the "Transcoding temporary files:" path on the dashboard and also check "Default recording path:" on DVR menu. Make sure they are both set to a drive with plenty of space. I know you said you checked but no idea how many drives or if one of these settings is pointed to a different location so it's good to check. How much space is available at the following location "/var/lib/emby/transcoding-temp" ?
ptlh2a 3 Posted June 29, 2020 Author Posted June 29, 2020 Good morning. /var is hanging off of /, and there is 80Gb available. Default recording path is blank, and so is Transcoding temporary files (so it should go to transcoding-temp). I started up a Live TV stream and verified that temp files are being placed in the path you listed (/var/lib/emby/transcoding-temp). Thanks. Pete
Carlo 4561 Posted June 29, 2020 Posted June 29, 2020 If you don't mind me asking what is your source of TV that you are using TVHeadend? Is it possible to setup you TV directly in Emby?
ptlh2a 3 Posted June 29, 2020 Author Posted June 29, 2020 (edited) Hauppauge WinTV Dual-HD. The TVHeadend server and the Emby server are the same physical system. There are no performance bottlenecks when both are running. I have watched LiveTV thru TVHeadend directly, and it runs for hours without any issues. I don't believe Emby has a way of directly connecting to this tuner. Edited June 29, 2020 by ptlh2a
Carlo 4561 Posted June 29, 2020 Posted June 29, 2020 Any reason why you aren't using that directly in Emby?
ptlh2a 3 Posted June 29, 2020 Author Posted June 29, 2020 Is there a way to direct connect? If there is, I would do that...I thought that you can use either SiliconDust or M3U connections for any other tuners (there were no other selections for Hauppauge). When I select "Other", and it goes thru the detect process, it does not detect my tuner. This is why I went thru M3U. Is there another way? More than willing to try. Pete
Carlo 4561 Posted June 29, 2020 Posted June 29, 2020 (edited) Have a read through the knowledge base article: https://support.emby.media/support/solutions/articles/44001160415-live-tv-setup Out of the box, Emby Server currently supports the following TV Tuners: HDHomerun Network Tuner (Models available for both OTA and Cable) Hauppauge TV Tuners (on Emby Server for Windows) M3U files (or urls). See examples of m3u files at http://xmtvplayer.com/build-m3u-file So if you are running on Windows you should be able to use your Hauppauge TV tuner directly. I do believe you have to have WINTV installed on the windows box first before setting up Emby to use it. Edited June 29, 2020 by cayars
ptlh2a 3 Posted June 29, 2020 Author Posted June 29, 2020 This isn't running Windows, so it cannot natively run Hauppauge tuners, which is why I am using an M3U. The server is an Ubuntu server. If you support M3U, it still should not have this issue (it runs for 30 minutes, so it is working at least somewhat). Are you advising me to either run my media server as Windows, or purchase and use a HDHomerun tuner?
Carlo 4561 Posted June 29, 2020 Posted June 29, 2020 I wouldn't say I was recommending that but both would be options. I was just suggesting if you were running Windows you could directly use the tuner with wintv installed. What do you mean if we support M3U? We do support this already.
ptlh2a 3 Posted June 29, 2020 Author Posted June 29, 2020 That is how I have Emby setup to receive TV stream from TVHeadend. It's set as an M3U Tuner, and TVHeadend handles working with the WinTV device.
