p4nda 25 Posted May 5, 2020 Posted May 5, 2020 (edited) Hello i manage all my media with "Tiny Media Manger" - i create my own nfo and save it with all the artwork in the movie folders in kodi standart i have really hard problems to get my movies scanned in emby i tryed everything some movies work some not its really strange i can not find out what i do wrong strange thing is on some movies it use local artwork and sometimes it adds this link buttons for imdb and trak in the overwiew but no title or other meta stuff some will get wrong title and not nearly the title from nfo even with right title and imdb id inside nfo i attached my folder structur complete with my local meta and a emby log (yea i know ffmp gets error thats coz its 0byte mkv i created for test porpuse .. even with the "real" files no meta scrapping possible) if i scan with jellyfin the same "test" folder it scrapped all movies with title meta etc right (screenshot from emby and jellyfin inside) i testet it on my lokal Synology install and on my webserver install - both running latest stable (4.4.2.0) and both installations habe problems to scrape my content or read the titel and meta from the local nfo mybe i dont know whats the right settings in add libary are? is there a trick? i know from kodi i can use settings like "use local data only" and plex even has something like thisand i know that emby should use local data before it looks outside right? i tryed with and without advanced settingschecking everything or uncheck everything in my exemple i attached i have 4 times the same movie (different version DC, uncut etc..) one works scrapping the other not? why?and one movie it only uses artwork from folder nothing else i can provide hunderts more they dont work :/ (i have thousends and some works ^^) scrapping my collection with kodi working perfect please help me i really want use emby as my media server ! i allready subscribe for premerie because i like it and hope its on my side that it dont work as i wish :/ let me know what infos you need i can provide all you want to fix this (if its a bug) what i dont want is that emby write to my nfo or save something in my media folders thats why i disabled everything who can do this (nfo saver and nfo meta played last thing) inside the RARfile are my test media folder with everything original and the mkv replaced with one with 0byte for filename etc http://wanna.see.my.p4nda.de/ShareX/log_metaa_screens.rar embyserver.txt Edited May 5, 2020 by p4nda
p4nda 25 Posted May 5, 2020 Author Posted May 5, 2020 (edited) i testet few more things i guess i know whats the problem is emby dont like "movie.nfo" it wants "filename.nfo" OR filename.nfo has a higher prio then "movie.nfo" if i have both inside so do i have override all my original scene release nfos or is there a way to choos if i want use filename.nfo or movie.nfo it is no problem for me to delete every nfo in my collection and let tiny media manager write the new ones but i would like to keep my original scene NFOs if possible :/ is there no way for your scrapper that do something like this?checking files inside folderah there are poster.jpg fanart.jpg - check use thislooking for *NFO files - two nfo files foundreading filename.nfo - negativ bad nfo checking other nforeading movie.nfo - allright there are everything i need Edited May 5, 2020 by p4nda
Luke 42213 Posted May 8, 2020 Posted May 8, 2020 Hi, so you're saying you have two different nfo's for the same video file?
p4nda 25 Posted May 8, 2020 Author Posted May 8, 2020 (edited) Yes i had two differnt nfos The original ones from the „scene“ and my self created ones with meta stuff called „movie.nfo“ But after deleting all nfos and switching from „movie.nfo“ to „filename.nfo“ it seems to scrap now everything in the right way trying with only „movie.nfo“ seems to not work properly .. nfo must be same name as the mkv Edited May 8, 2020 by p4nda
Luke 42213 Posted May 8, 2020 Posted May 8, 2020 Ok I guess that's something that would require settings to allow you to prioritize.
crusher11 1134 Posted May 8, 2020 Posted May 8, 2020 Get your media legally and you don't have that problem.
FrostByte 5437 Posted May 8, 2020 Posted May 8, 2020 Or, use the xml files instead of nfo files for Emby 1
p4nda 25 Posted May 8, 2020 Author Posted May 8, 2020 (edited) Ok I guess that's something that would require settings to allow you to prioritize. no problem i dont need that i fixed it by replacing every nfo with new ones .. i came from kodi and there work nfo files who only called "movie.nfo" instead of filename.nfo <VideoFileName>.nfo NFO Files are named the same as the video file except with the .nfo extension. See image below. We recommend using this format to name nfo files. movie.nfo Kodi may also scan nfo files named movie.nfo. To use this name, the setting Movies are in separate folders that match the movie title must be Enabled Get your media legally and you don't have that problem. thx for the tipp ... my bad.. i didnt know that legally media would be scrapped better Or, use the xml files instead of nfo files for Emby tinyMediaManager didnt have the option for export xml it only can write nfo but no problem there is a option inside for setting nfo to filename and that fixed everything for me anyways thx for your time i love emby! Edited May 8, 2020 by p4nda 3
