lifespeed 42 Posted May 5, 2020 Posted May 5, 2020 (edited) Would it be possible to display the channel alongside (underneath, on top?) the channel logo artwork? It is sooooooo difficult to try to decipher these tiny icons, which usually don't have any channel number info. While logos may have some value, and are pretty, the channel number is indispensable while attempting to scroll through what could be hundreds of possibilities. I understand screen real estate is severely limited, but leaving the channel number out just isn't a good UI decision. Something has to give, even if it means fewer lines of guide per screen. We need the channel number!! Edited May 5, 2020 by lifespeed
Luke 42244 Posted May 5, 2020 Posted May 5, 2020 Options are possible for the future. Thanks for the feedback.
Solution lifespeed 42 Posted May 14, 2020 Author Solution Posted May 14, 2020 This has been implemented, it is so much easier to find channels in the guide now. Thanks! 1
