byakuya32 24 Posted May 4, 2020 Posted May 4, 2020 you should add an option to bypass or flac converting the audio on video converts so we can keep the original lossless audio intact.
mastrmind11 722 Posted May 4, 2020 Posted May 4, 2020 if your device is capable of playing it natively then emby will direct play it. if not, it'll swap containers or transcode the media so it actually plays on said device.
byakuya32 24 Posted May 4, 2020 Author Posted May 4, 2020 I ment when converting to hvec to no have it touch the audio just the video.
PenkethBoy 2068 Posted May 5, 2020 Posted May 5, 2020 if you want control over the result dont use the emby convert use ffmpeg or if that's not to your liking there are numerous tools better suited then emby's convert feature
