Luke 42246 Posted March 23, 2021 Posted March 23, 2021 20 hours ago, sittingmongoose said: @Lukehaving an issue with getting hardware transcoding working. I used to have nvidia as an option under advanced, but now no matter what i do i cant get quicksync or nvidia to show up. I even wiped the docker and all data thinking maybe something got messed up. I am running a 9900k, p2000 on Unraid 6.9.2, using emby server 4.6.34. Plex sees my p2000 fine and so does Tdarr. I have tried linux server emby docker beta, and the emby offcial beta docker. Both give the same results. I can ls and see the igpu fine. Things ive tried for Nvidia. I added --runtime=nvidia, the visible devices variable and device capabilities variable. These are the settings that work for plex and tdarr. Things ive tried for Intel. I added --device=/dev/dri and i also tried adding it as a device. Both options give the same result. There are no options in my advanced section of transcoders. I am no longer able to use the Emby official beta docker because now I get an error saying port 1900 is already being used. I get around this by removing that variable in the linux server docker. Hi there, please take a look at this and see if it helps: Thanks.
sittingmongoose 5 Posted March 23, 2021 Posted March 23, 2021 8 minutes ago, Luke said: Hi there, please take a look at this and see if it helps: Thanks. That does not help. I cant get either IGPU nor Nvidia to work. I am able to get them to work in other dockers though. I have tried just using nvidia settings, and tried just using intel settings. Perhaps its an issue with the container image I am using. Any ideas how to fix emby's official docker giving an error for port 1900 in use? I believe it's for dlna.
Luke 42246 Posted March 23, 2021 Posted March 23, 2021 6 minutes ago, sittingmongoose said: That does not help. I cant get either IGPU nor Nvidia to work. I am able to get them to work in other dockers though. I have tried just using nvidia settings, and tried just using intel settings. Perhaps its an issue with the container image I am using. Any ideas how to fix emby's official docker giving an error for port 1900 in use? I believe it's for dlna. I can't provide a definitive answer about containers built by others, but I can say that many are successfully following that procedure for our official container. Regarding the 1900 port, please start a new topic: Thanks.
sittingmongoose 5 Posted March 23, 2021 Posted March 23, 2021 29 minutes ago, Luke said: I can't provide a definitive answer about containers built by others, but I can say that many are successfully following that procedure for our official container. Regarding the 1900 port, please start a new topic: Thanks. I was able to resolve the nvidia and port issue by wiping everything, and downloading the official emby docker beta. Looks like the linux server one doesnt work. Now I cant get intel igpu sorted out...
