ade05fr 0 Posted May 4, 2020 Posted May 4, 2020 Hi, i have a problem with emby when i play it with emby droid on my videoprojector. In fact if i use a headset the voice are only on the right speaker not on the left. The mkv is correct because if i play it through vlc for example with my headset i have the voices on both speakers. What is the issue ? is it related to the fact that the mkv is 5.1 or 6.1 encoded ? thanks
ade05fr 0 Posted May 4, 2020 Author Posted May 4, 2020 emby for android tv last version of google store : 1.7.92g
ebr 16338 Posted May 4, 2020 Posted May 4, 2020 Can you please describe all the components and how they are connected? Is the incorrect channel mapping on all media or just some?
ade05fr 0 Posted May 5, 2020 Author Posted May 5, 2020 Well it's an xgimi h2 with Android 8 integrated. I use emby for Android TV to watch movies through wifi n. The sound is ok with the projector speakers but with the headset the voice channel is only on one side. What do you mean by incorrect channel mapping? I just play the mkv without any change on emby or the mkv file.the only thing is that it's a 5.1 mkv file.
ebr 16338 Posted May 5, 2020 Posted May 5, 2020 Hi. What kind of headset and how is it connected? (BT I assume?) Are other sounds spread properly across both sides?
ade05fr 0 Posted May 5, 2020 Author Posted May 5, 2020 My headset : Marshall Major 2. I tried both with BT and wired its the same. The others sound are properly dispatch only voice are on one side. thanks -
ebr 16338 Posted May 5, 2020 Posted May 5, 2020 Is the app audio setting on Auto or mix down? Whichever one it is on, can you try the other? Have you confirmed that the projector is outputting the sound properly with other content?
rbjtech 5345 Posted May 5, 2020 Posted May 5, 2020 Hi, i have a problem with emby when i play it with emby droid on my videoprojector. In fact if i use a headset the voice are only on the right speaker not on the left. The mkv is correct because if i play it through vlc for example with my headset i have the voices on both speakers. What is the issue ? is it related to the fact that the mkv is 5.1 or 6.1 encoded ? thanks is it just one file that has the issue or all MKV files ? if just one, then I'd imagine the file is the issue - VLC is simply adapting the audio while emby is not. a 'MediaInfo' extract of the Audio section of the file would also be useful to determine the audio encoding. Example -
ade05fr 0 Posted May 6, 2020 Author Posted May 6, 2020 The problem occurs on a lot of MKV files When you talk in audio settings where is located the parameterto be set on emby for android ? Here is info to one mkv file for example $ ffprobe -v error -show_format -show_streams "myFile.mkv" [STREAM] index=0 codec_name=h264 codec_long_name=H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 profile=High codec_type=video codec_time_base=1001/48000 codec_tag_string=[0][0][0][0] codec_tag=0x0000 width=1920 height=1080 coded_width=1920 coded_height=1088 has_b_frames=2 sample_aspect_ratio=1:1 display_aspect_ratio=16:9 pix_fmt=yuv420p level=40 color_range=tv color_space=bt709 color_transfer=bt709 color_primaries=bt709 chroma_location=left field_order=progressive timecode=N/A refs=1 is_avc=true nal_length_size=4 id=N/A r_frame_rate=24000/1001 avg_frame_rate=24000/1001 time_base=1/1000 start_pts=0 start_time=0.000000 duration_ts=N/A duration=N/A bit_rate=N/A max_bit_rate=N/A bits_per_raw_sample=8 nb_frames=N/A nb_read_frames=N/A nb_read_packets=N/A DISPOSITION:default=1 DISPOSITION:dub=0 DISPOSITION:original=0 DISPOSITION:comment=0 DISPOSITION:lyrics=0 DISPOSITION:karaoke=0 DISPOSITION:forced=0 DISPOSITION:hearing_impaired=0 DISPOSITION:visual_impaired=0 DISPOSITION:clean_effects=0 DISPOSITION:attached_pic=0 DISPOSITION:timed_thumbnails=0 TAG:BPS-eng=8456505 TAG:DURATION-eng=00:38:46.199000000 TAG:NUMBER_OF_FRAMES-eng=55773 TAG:NUMBER_OF_BYTES-eng=2458939236 TAG:_STATISTICS_WRITING_APP-eng=mkvmerge v40.0.0 ('Old Town Road + Pony') 64-bit TAG:_STATISTICS_WRITING_DATE_UTC-eng=2019-11-12 15:27:10 TAG:_STATISTICS_TAGS-eng=BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES [/STREAM] [STREAM] index=1 codec_name=eac3 codec_long_name=ATSC A/52B (AC-3, E-AC-3) profile=unknown codec_type=audio codec_time_base=1/48000 codec_tag_string=[0][0][0][0] codec_tag=0x0000 sample_fmt=fltp sample_rate=48000 channels=6 channel_layout=unknown bits_per_sample=0 dmix_mode=-1 ltrt_cmixlev=-1.000000 ltrt_surmixlev=-1.000000 loro_cmixlev=-1.000000 loro_surmixlev=-1.000000 id=N/A r_frame_rate=0/0 avg_frame_rate=0/0 time_base=1/1000 start_pts=0 start_time=0.000000 duration_ts=N/A duration=N/A bit_rate=N/A max_bit_rate=N/A bits_per_raw_sample=N/A nb_frames=N/A nb_read_frames=N/A nb_read_packets=N/A DISPOSITION:default=1 DISPOSITION:dub=0 DISPOSITION:original=0 DISPOSITION:comment=0 DISPOSITION:lyrics=0 DISPOSITION:karaoke=0 DISPOSITION:forced=0 DISPOSITION:hearing_impaired=0 DISPOSITION:visual_impaired=0 DISPOSITION:clean_effects=0 DISPOSITION:attached_pic=0 DISPOSITION:timed_thumbnails=0 TAG:language=eng TAG:BPS-eng=768000 TAG:DURATION-eng=00:38:46.208000000 TAG:NUMBER_OF_FRAMES-eng=72694 TAG:NUMBER_OF_BYTES-eng=223315968 TAG:_STATISTICS_WRITING_APP-eng=mkvmerge v40.0.0 ('Old Town Road + Pony') 64-bit TAG:_STATISTICS_WRITING_DATE_UTC-eng=2019-11-12 15:27:10 TAG:_STATISTICS_TAGS-eng=BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES [/STREAM] [FORMAT] filename=myFile.mkv nb_streams=2 nb_programs=0 format_name=matroska,webm format_long_name=Matroska / WebM start_time=0.000000 duration=2326.208000 size=2683145484 bit_rate=9227534 probe_score=100 TAG:encoder=libebml v1.3.9 + libmatroska v1.5.2 TAG:creation_time=2019-11-12T15:27:10.000000Z [/FORMAT]
ebr 16338 Posted May 6, 2020 Posted May 6, 2020 This is interesting: channel_layout=unknown How was this file created? Can you play these same files on the same device through the same headset using any other media player and they play correctly? The app settings are accessible from the "cog" icon on the app home screen. The audio setting is under "Playback". 1
rbjtech 5345 Posted May 6, 2020 Posted May 6, 2020 (edited) @@ebr - using the same ffprobe command line - I get the channel_layout=5.1(side) for DTS and AC3 but for EAC3 mine also says 'Unknown' (but plays/maps just fine), so I'm not sure if that is the issue here. Edited May 6, 2020 by rbjtech
ade05fr 0 Posted May 6, 2020 Author Posted May 6, 2020 With vlc everything works fine for all the mkv files. The problem is still here event with the changes in the playback settings.
