roaku 842 Posted January 22, 2021 Posted January 22, 2021 (edited) 3 minutes ago, bakes82 said: The issue is a base item can have multi sources correct? 720p, 1080p? So you need to get the info from the media source. Looks like we're advising him to do the same thing. Edited January 22, 2021 by roaku
bakes82 167 Posted January 22, 2021 Posted January 22, 2021 How does this plugin work when you have things merged: 1
bakes82 167 Posted January 22, 2021 Posted January 22, 2021 Just now, roaku said: Looks like we're advising him to do the same thing. Sure lol, but he needs the context too, as it could impact how tagging works in general. If tags are on the base item, how do you block just the 4k item or do you block them all?
roaku 842 Posted January 22, 2021 Posted January 22, 2021 2 minutes ago, bakes82 said: How does this plugin work when you have things merged: BaseItem.GetMediaSources(...) gets you the MediaStream details for multi-versions.
roaku 842 Posted January 22, 2021 Posted January 22, 2021 For the image enhancement plug in I'm working on, I match when *any* of the versions fulfill a rule. A similar decision has to be made for the tagging. If any of the versions match, does the item get the tag? 1
bakes82 167 Posted January 22, 2021 Posted January 22, 2021 2 minutes ago, roaku said: BaseItem.GetMediaSources(...) gets you the MediaStream details for multi-versions. Yes I know it does, but when you applied a "4k" tag, does it apply to the base item of all the merge, or to the mediasourceitem 1
roaku 842 Posted January 22, 2021 Posted January 22, 2021 Just now, bakes82 said: Yes I know it does, but when you applied a "4k" tag, does it apply to the base item of all the merge, or to the mediasourceitem That's what sucks a bit about the multi-version set up...there's no quick access to 'sibling' items, right? There has to be additional querying if GetMediaSources has multiple entries *and* you find a match in one of the non-primary MediaSources.
bakes82 167 Posted January 22, 2021 Posted January 22, 2021 Just now, roaku said: That's what sucks a bit about the multi-version set up...there's no quick access to 'sibling' items, right? There has to be additional querying if GetMediaSources has multiple entries *and* you find a match in one of the non-primary MediaSources. Right but the use case it, I want to block 4k tagged items, now where does the 4k tag live? will it block the entire 1917 move because it has a source of 4k and a tag of 4k and a source of 1080p and a 1080p tag. This is more my question. Why Ive been asking all along, what is the real use case, as it might not be doable in all setups with a tag, especially if there is only 1 item and it has 10 tags now. Hopefully that makes sense.
roaku 842 Posted January 22, 2021 Posted January 22, 2021 1 minute ago, bakes82 said: Right but the use case it, I want to block 4k tagged items, now where does the 4k tag live? will it block the entire 1917 move because it has a source of 4k and a tag of 4k and a source of 1080p and a 1080p tag. This is more my question. Why Ive been asking all along, what is the real use case, as it might not be doable in all setups with a tag, especially if there is only 1 item and it has 10 tags now. Hopefully that makes sense. I think the simplest solution would be to get all the Items through the main endpoint instead of the User endpoint. The main endpoint can return all the items, ignoring the multi-version groupings.
roaku 842 Posted January 22, 2021 Posted January 22, 2021 (edited) This endpoint separates the items from their version groupings and lists them separately: /emby/Items?api_key={apikey}&Recursive=true&IncludeItemTypes=Movie&Fields=Path,TagLines,Overview,PremiereDate,Genres,MediaStreams&SortBy=Name&SortOrder=Ascending This endpoint returns only the primary items in a version group: /emby/Users/{userid}/Items?api_key={apikey}&Recursive=true&IncludeItemTypes=Movie&Fields=Path,TagLines,Overview,PremiereDate,Genres,MediaStreams&SortBy=Name&SortOrder=Ascending Edited January 22, 2021 by roaku 1
bakes82 167 Posted January 22, 2021 Posted January 22, 2021 3 minutes ago, roaku said: This endpoint separates the items from their version groupings and lists them separately: /emby/Items?api_key={apikey}&Recursive=true&IncludeItemTypes=Movie&Fields=Path,TagLines,Overview,PremiereDate,Genres,MediaStreams&SortBy=Name&SortOrder=Ascending This endpoint only returns only the primary items in a version group: /emby/Users/{userid}/Items?api_key={apikey}&Recursive=true&IncludeItemTypes=Movie&Fields=Path,TagLines,Overview,PremiereDate,Genres,MediaStreams&SortBy=Name&SortOrder=Ascending Sidebar: you know of a way to make the primary always be like 4k if you have duplicates, now it seems random based on how you merged what with what
roaku 842 Posted January 22, 2021 Posted January 22, 2021 (edited) 3 minutes ago, bakes82 said: Sidebar: you know of a way to make the primary always be like 4k if you have duplicates, now it seems random based on how you merged what with what My understanding is that there is magic done by Emby to determine the 'best' candidate from the versions for the particular device/network conditions requesting the media and there's no way to just have it be alpha sorted or something similar. I'd have to look up the forum posts where the devs talk about that. I use multi-versions to store alternate cuts of movies dubbed/subtitled...I've been told we're not really supposed to do that...even though the Knowledge Base is where I learned how. Edited January 22, 2021 by roaku
bakes82 167 Posted January 22, 2021 Posted January 22, 2021 1 minute ago, roaku said: My understanding is that there is magic done by Emby to determine the 'best' candidate from the versions for the particular device/network conditions requesting the media and there's no way to just have it be alpha sorted or something similar. I'd have to look up the forum posts where the devs talk about that. Right but the UI displays info from the 1st one in the drop down list IDK how that list is populated, I would always want the highest bitrate first. I know emby does other magic, but I turn that shit off, I set mine to max quality, otherwise if you have like a 4k and a 4kdv the dv is higher bitrate, sometimes emby will still pick 1080p because the speedtest was slow atm but the 4k dv 130gb file plays fine with no buffering
roaku 842 Posted January 22, 2021 Posted January 22, 2021 1 minute ago, bakes82 said: Right but the UI displays info from the 1st one in the drop down list IDK how that list is populated, I would always want the highest bitrate first. I know emby does other magic, but I turn that shit off, I set mine to max quality, otherwise if you have like a 4k and a 4kdv the dv is higher bitrate, sometimes emby will still pick 1080p because the speedtest was slow atm but the 4k dv 130gb file plays fine with no buffering That part might be by file date created/modified or when the file was scanned into the db? I seem to remember being able to manipulate that a bit before I gave up trying to have control of it.
chef 3811 Posted January 22, 2021 Posted January 22, 2021 (edited) So it sounds like I might have stumbled into this first ... uh .... 100th issue. Tagging the baseItem might not work for resolution because the baseItem contains many stream object. This shows a rule which say the user wants to target Resolution 1080p. But, like you guys have mentioned the baseItem contains many streams. It could have 1080p and 2160p. This causes an issue for tagging the baseItem. We can't tag a baseItem with two different rules, because (if the whole idea is to limit accessibility to an item) we would most likely, indirectly, tag both item streams. Crap! we'll have to think this through a bit further. There is a 'gotcha' here which might make it harder to target and tag baseItems by Resolution. Edited January 22, 2021 by chef
roaku 842 Posted January 22, 2021 Posted January 22, 2021 4 minutes ago, chef said: So it sounds like I might have stumbled into this first ... uh .... 100th issue. Tagging the baseItem might not work for resolution because the baseItem contains many stream object. This shows a rule which say the user wants to target Resolution 1080p. In the schedule task I can do something like this: foreach (var stream in item.GetMediaStreams()) { if (stream.Width != null) { if (stream.Width == Convert.ToInt32(rule.Profile.Resolution.Replace("p", string.Empty))) { } } } This would target the stream with a width of what ever the 'rule.Profile.Resoultion' is. Note: 1080p => 1080px width, 2160p => 2160px width (correct me if I'm wrong). But, like you guys have mentioned the baseItem contains many streams. It could have 1080p and 2160p. This causes an issue for tagging the baseItem. We can't tag a baseItem with two different rules, because (if the whole idea is to limit accessibility to an item) we would most likely, indirectly, tag both item streams. Crap! we'll have to think this through a bit further. There is a 'gotcha' here which might make it harder to target and tag baseItems by Resolution. Did you see this suggestion here to try getting the items ungrouped by version instead: I think that this way, you'd be able to only ever look at the MediaStreams for that particular BaseItem (I'll look up the method/property for that) and manipulate the tags for that particular BaseItem. 1
roaku 842 Posted January 22, 2021 Posted January 22, 2021 I believe using BaseItem.GetMediaStreams() will return you only the MediaStreams for that particular Item. 1
chef 3811 Posted January 22, 2021 Posted January 22, 2021 32 minutes ago, roaku said: This endpoint separates the items from their version groupings and lists them separately: /emby/Items?api_key={apikey}&Recursive=true&IncludeItemTypes=Movie&Fields=Path,TagLines,Overview,PremiereDate,Genres,MediaStreams&SortBy=Name&SortOrder=Ascending This endpoint returns only the primary items in a version group: /emby/Users/{userid}/Items?api_key={apikey}&Recursive=true&IncludeItemTypes=Movie&Fields=Path,TagLines,Overview,PremiereDate,Genres,MediaStreams&SortBy=Name&SortOrder=Ascending I the case of a 'user-less' request, does each stream have an internalId (or Id in the REST case) attached to it. I'll check it out. If it does, then this is what we' can do. We just have to make sure we can tag an item with an internalId.
bakes82 167 Posted January 22, 2021 Posted January 22, 2021 4 minutes ago, chef said: I the case of a 'user-less' request, does each stream have an internalId (or Id in the REST case) attached to it. I'll check it out. If it does, then this is what we' can do. We just have to make sure we can tag an item with an internalId. do you have code someplace for me to view?
roaku 842 Posted January 22, 2021 Posted January 22, 2021 1 minute ago, chef said: I the case of a 'user-less' request, does each stream have an internalId (or Id in the REST case) attached to it. I'll check it out. If it does, then this is what we' can do. We just have to make sure we can tag an item with an internalId. Going by memory, but I recall it having the right values for the 'hidden' items for both Id and InternalId 1
bakes82 167 Posted January 22, 2021 Posted January 22, 2021 Just now, roaku said: Going by memory, but I recall it having the right values for the 'hidden' items for both Id and InternalId the c# api this way does NOT have an id var mediaSourceItem = sessionManagerSession.FullNowPlayingItem.GetMediaSources(false, false, new LibraryOptions()) .SingleOrDefault(x => string.Equals(x.Id, sessionManagerSession.PlayState.MediaSourceId, StringComparison.OrdinalIgnoreCase)); mediaSourceItem.MediaStreams.First().
roaku 842 Posted January 22, 2021 Posted January 22, 2021 1 minute ago, bakes82 said: the c# api this way does NOT have an id var mediaSourceItem = sessionManagerSession.FullNowPlayingItem.GetMediaSources(false, false, new LibraryOptions()) .SingleOrDefault(x => string.Equals(x.Id, sessionManagerSession.PlayState.MediaSourceId, StringComparison.OrdinalIgnoreCase)); mediaSourceItem.MediaStreams.First(). We would want InternalId in this case.
bakes82 167 Posted January 22, 2021 Posted January 22, 2021 Just now, roaku said: We would want InternalId in this case. Yeah I know, doesnt exist on the object returned // Decompiled with JetBrains decompiler // Type: MediaBrowser.Model.Entities.MediaStream // Assembly: MediaBrowser.Model, Version=4.5.0.28, Culture=neutral, PublicKeyToken=null // MVID: D6209AB7-0B07-4E22-B19D-786FB4321F01 // Assembly location: C:\Users\bradl\.nuget\packages\mediabrowser.common\4.5.0.28\lib\netstandard2.0\MediaBrowser.Model.dll using MediaBrowser.Model.Dlna; using MediaBrowser.Model.MediaInfo; using System; namespace MediaBrowser.Model.Entities { public class MediaStream { private static ReadOnlyMemory<char>[] GraphicSubCodecNames = new ReadOnlyMemory<char>[3] { "DVB_TELETEXT".AsMemory(), "sub".AsMemory(), "dvb_subtitle".AsMemory() }; private static ReadOnlyMemory<char>[] GraphicSubCodecPartialNames = new ReadOnlyMemory<char>[3] { "pgs".AsMemory(), "dvd".AsMemory(), "dvbsub".AsMemory() }; private static ReadOnlyMemory<char> AssCodecName = "ass".AsMemory(); private static ReadOnlyMemory<char> SsaCodecName = "ssa".AsMemory(); public string Codec { get; set; } public string CodecTag { get; set; } public string Language { get; set; } public string ColorTransfer { get; set; } public string ColorPrimaries { get; set; } public string ColorSpace { get; set; } public string Comment { get; set; } public long? StreamStartTimeTicks { get; set; } public string TimeBase { get; set; } public string CodecTimeBase { get; set; } public string Title { get; set; } public string Extradata { get; set; } public string VideoRange { get { if (this.Type != MediaStreamType.Video) return (string) null; string colorTransfer = this.ColorTransfer; return !string.IsNullOrEmpty(colorTransfer) && (string.Equals(colorTransfer, "smpte2084", StringComparison.OrdinalIgnoreCase) || string.Equals(colorTransfer, "arib-std-b67", StringComparison.OrdinalIgnoreCase)) ? "HDR" : "SDR"; } } public string DisplayTitle { get; set; } public string DisplayLanguage { get; set; } public string NalLengthSize { get; set; } public bool IsInterlaced { get; set; } public bool? IsAVC { get; set; } public string ChannelLayout { get; set; } public int? BitRate { get; set; } public int? BitDepth { get; set; } public int? RefFrames { get; set; } [Obsolete("Currently this property doesn't have any write usage.'")] public int? PacketLength { get; set; } public int? Channels { get; set; } public int? SampleRate { get; set; } public bool IsDefault { get; set; } public bool IsForced { get; set; } public int? Height { get; set; } public int? Width { get; set; } public float? AverageFrameRate { get; set; } public float? RealFrameRate { get; set; } public string Profile { get; set; } public MediaStreamType Type { get; set; } public string AspectRatio { get; set; } public int Index { get; set; } public int? Score { get; set; } public bool IsExternal { get; set; } public SubtitleDeliveryMethod? DeliveryMethod { get; set; } public string DeliveryUrl { get; set; } public bool? IsExternalUrl { get; set; } public bool IsTextSubtitleStream { get { if (this.Type != MediaStreamType.Subtitle) return false; string codec = this.Codec; return (!string.IsNullOrEmpty(codec) || this.IsExternal) && MediaStream.IsTextFormat(codec.AsSpan()); } } public static bool IsTextFormat(ReadOnlySpan<char> codec) { if (codec.IsEmpty) return true; foreach (ReadOnlyMemory<char> graphicSubCodecName in MediaStream.GraphicSubCodecNames) { if (MemoryExtensions.Equals(graphicSubCodecName.Span, codec, StringComparison.OrdinalIgnoreCase)) return false; } foreach (ReadOnlyMemory<char> codecPartialName in MediaStream.GraphicSubCodecPartialNames) { if (codec.Contains(codecPartialName.Span, StringComparison.OrdinalIgnoreCase)) return false; } return true; } public bool SupportsSubtitleConversionTo(ReadOnlySpan<char> toCodec) { if (!this.IsTextSubtitleStream) return false; ReadOnlySpan<char> span1 = MediaStream.AssCodecName.Span; ReadOnlySpan<char> span2 = MediaStream.SsaCodecName.Span; if (MemoryExtensions.Equals(span1, toCodec, StringComparison.OrdinalIgnoreCase) || MemoryExtensions.Equals(span2, toCodec, StringComparison.OrdinalIgnoreCase)) return false; ReadOnlySpan<char> other = this.Codec.AsSpan(); return !MemoryExtensions.Equals(span1, other, StringComparison.OrdinalIgnoreCase) && !MemoryExtensions.Equals(span2, other, StringComparison.OrdinalIgnoreCase); } public bool SupportsExternalStream { get; set; } public string Path { get; set; } public MediaProtocol Protocol { get; set; } public string PixelFormat { get; set; } public double? Level { get; set; } public bool? IsAnamorphic { get; set; } public override string ToString() => string.Format("{0}: {1} {2}", (object) this.Type, (object) this.Codec, (object) this.DisplayTitle); } } 1
roaku 842 Posted January 22, 2021 Posted January 22, 2021 The value we need is exposed as 'Id' through the rest api: /emby/Items?api_key={apikey}&Recursive=true&IncludeItemTypes=Movie&Fields=Path,TagLines,Overview,PremiereDate,Genres,MediaStreams&SortBy=Name&SortOrder=Ascending [ { "Name": "Airplane!", "ServerId": "84be18a2e4db4328ab7b6fe164491562", "Id": "1402", "Container": "mkv", "PremiereDate": "1980-07-01T06:00:00.0000000+00:00", ... }, { "Name": "Airplane!", "ServerId": "84be18a2e4db4328ab7b6fe164491562", "Id": "1403", "Container": "mkv", "PremiereDate": "1980-07-02T05:00:00.0000000+00:00", ... } ]
chef 3811 Posted January 22, 2021 Posted January 22, 2021 Then resolution is a problem. Was that in the OP request? Limiting access to 4k streams through tagging?
