skank 85 Posted May 3, 2020 Posted May 3, 2020 I'm wondering , im using emby for kodi. If i want to add trakt.tv suppport... do i need to link this then to emby or do i need to link kodi to trakt.tv? Cause if i link emby with kodi.. how does rating work then in kodi?
prydda 2 Posted May 3, 2020 Posted May 3, 2020 If I remeber correctly the trakt.tv emby server addon is kinda broken/buggy.
WilhelmStroker 107 Posted May 3, 2020 Posted May 3, 2020 https://emby.media/community/index.php?/topic/59534-how-to-handle-trakttv/
skank 85 Posted May 3, 2020 Author Posted May 3, 2020 If I remeber correctly the trakt.tv emby server addon is kinda broken/buggy. Ouch truly?
Luke 42234 Posted May 3, 2020 Posted May 3, 2020 Is the trakt addon now working or not? Hi there, which trakt addon are you referring to?
skank 85 Posted May 3, 2020 Author Posted May 3, 2020 Hi there, which trakt addon are you referring to? The emby server one As i said, i use emby for kodi I think the best way is to use emby server -> to trakt instead of kodi -> trakt
Nick Rosier 3 Posted May 3, 2020 Posted May 3, 2020 The emby server one As i said, i use emby for kodi I think the best way is to use emby server -> to trakt instead of kodi -> trakt The easiest way is indeed to link emby to trakt. Your Emby-server and devices stay in sync with only 1 place to configure but... ....as stated above, the plugin (at least for me and some others) can be a bit buggy/limited compared to the Kodi-version. My main issues: play state is not synced; if you pause an episode on Trakt it continues to "play". This was not the case with the Kodi version. play a previously played episode and stop it immediately (e.g. you started wrong episode): ALL previous scrobbles on Trakt get erased! I've considered switching back to the Kodi version but am afraid it could introduce more issues: what happens if Device 1 scrobbles to Trakt, Device B picks up the scrobble. Emby also gets the file was played from A and syncs this to device B. Does B now have 2 plays?
skank 85 Posted May 4, 2020 Author Posted May 4, 2020 Mmm indeed. Think i will go to the emby to trakt sync
