tmysik 9 Posted September 3, 2020 Author Posted September 3, 2020 I do. Actually, it is even worse now. Even if I have those 2 plugins (DLNA + Port Mapper) installed, I have to restart Emby in order to be able to connect to it and use it. This happens not every day but very often. I was not able to find the exact cause/rule why it happens.
Luke 42241 Posted September 3, 2020 Posted September 3, 2020 3 hours ago, tmysik said: I do. Actually, it is even worse now. Even if I have those 2 plugins (DLNA + Port Mapper) installed, I have to restart Emby in order to be able to connect to it and use it. This happens not every day but very often. I was not able to find the exact cause/rule why it happens. Can you please attach the emby server log from when this happened? Thanks.
tmysik 9 Posted September 9, 2020 Author Posted September 9, 2020 Thanks for your will. It just happened, 1 minute ago (I had to disable and enable Emby, see the attached screenshot). Attaching all the logs from today. Thanks! embyserver-63735228032.txt embyserver-63735261179.txt embyserver.txt hardware_detection-63735228077.txt hardware_detection-63735261241.txt
tmysik 9 Posted September 9, 2020 Author Posted September 9, 2020 BTW I tried to connect via browser and the connection was refused (mobile app showed the "welcome" screen where one can select server, etc.).
tmysik 9 Posted September 10, 2020 Author Posted September 10, 2020 And here it is again, the browser says: ERR_CONNECTION_REFUSED.
tmysik 9 Posted September 10, 2020 Author Posted September 10, 2020 Logs from today: embyserver-63735314438.txt embyserver-63735321557.txt embyserver.txt hardware_detection-63735321612.txt
tmysik 9 Posted September 10, 2020 Author Posted September 10, 2020 Just to complete the information: - my QNAP NAS is automatically turned off at ~12am - my QNAP NAS is automatically turned on at ~6am Formerly (older versions of Emby, not sure if 4.2- or 4.1-), this worked without any problem. Thank you.
Luke 42241 Posted September 16, 2020 Posted September 16, 2020 Ok, we'll have a new release out soon. You could always try the beta server and see if that helps.
tmysik 9 Posted September 16, 2020 Author Posted September 16, 2020 I will wait for the stable version and let you know. So, I guess - nothing in the logs, right? Thanks!
tmysik 9 Posted September 16, 2020 Author Posted September 16, 2020 Can I turn debug on or something, on the server? And, in the client (mobile, web), there has to be some error, right?
tmysik 9 Posted September 29, 2020 Author Posted September 29, 2020 @Luke Unfortunately, just happened to me again, with version 4.5.0. NAS went into the standby mode during the day, now, it started once I connected to it via my Android QNAP app. But Emby was not working, I had to manually restart it.
Luke 42241 Posted September 29, 2020 Posted September 29, 2020 18 minutes ago, tmysik said: @Luke Unfortunately, just happened to me again, with version 4.5.0. NAS went into the standby mode during the day, now, it started once I connected to it via my Android QNAP app. But Emby was not working, I had to manually restart it. Can you please attach a new server log from that? Thanks.
tmysik 9 Posted September 30, 2020 Author Posted September 30, 2020 Today, it happened too so attaching logs from yesterday as well as today. Thanks! embyserver-63736956041.txt embyserver-63737004838.txt embyserver-63737012077.txt embyserver-63737020800.txt embyserver-63737042435.txt embyserver-63737052808.txt embyserver.txt hardware_detection-63737004900.txt hardware_detection-63737012156.txt
Luke 42241 Posted October 3, 2020 Posted October 3, 2020 On 9/30/2020 at 2:57 AM, tmysik said: Today, it happened too so attaching logs from yesterday as well as today. Thanks! embyserver-63736956041.txt 8.22 kB · 0 downloads embyserver-63737004838.txt 13.04 kB · 0 downloads embyserver-63737012077.txt 162.22 kB · 0 downloads embyserver-63737020800.txt 112.87 kB · 0 downloads embyserver-63737042435.txt 6.6 kB · 0 downloads embyserver-63737052808.txt 12.72 kB · 0 downloads embyserver.txt 71.25 kB · 0 downloads hardware_detection-63737004900.txt 152.56 kB · 0 downloads hardware_detection-63737012156.txt 152.56 kB · 0 downloads What time did you expect the machine to sleep?
Luke 42241 Posted October 3, 2020 Posted October 3, 2020 What date and time did you expect the machine sleep but it did not?
tmysik 9 Posted October 3, 2020 Author Posted October 3, 2020 I don't understand. The problem is not that QNAP is not going to the stand-by mode. It does. The problem is that once it wakes up (because I connect to its Samba, for example), Emby server "does not run" (I cannot connect to it). All other services are working fine. Once I restart Emby, it works again.
Luke 42241 Posted October 3, 2020 Posted October 3, 2020 You gave me 7 server log files to look at. That's a lot of information, that's why I'm asking What date and time did you expect the machine sleep but it did not? This way I can just look at that one specific log file. Thanks.
tmysik 9 Posted October 3, 2020 Author Posted October 3, 2020 I see now, sorry. In such a case, I am not sure and will let you know next time once I attach logs again. I will provide exact time when I woke up my NAS again.
tmysik 9 Posted October 5, 2020 Author Posted October 5, 2020 Just happened to me right now: QNAP wakes up (at 9:25 am) but Emby does not. Emby restarted at 9:25 am. When exactly went QNAP into the stand-by mode cannot be easily found out, the last message in the log is at 7 am: hardware_detection-63737486844.txtembyserver.txtembyserver-63737486808.txtembyserver-63737474435.txt
Luke 42241 Posted October 5, 2020 Posted October 5, 2020 I thought we were talking about emby preventing the nas from being able to sleep?
tmysik 9 Posted October 5, 2020 Author Posted October 5, 2020 Ha, you are right! I have misused this thread. Should I start a new one? This one can be closed since it already works. Thank you and sorry for inconveniences, my bad. 1
