darengibo 6 Posted July 6, 2014 Posted July 6, 2014 If I am just missing an obvious topic, let me know! I was wondering if we could customize Chocoloate theme.. trying to figure out how to put a png for each library (movies, tv, etc).. when Chocolate first opens and you click on a library it shows recent additions and i would like to add that png to the right... hope that made sense!!! thanks,
Solution ebr 16346 Posted July 6, 2014 Solution Posted July 6, 2014 This is independent of the theme or even the app you are using to access your media. You can manage images for all items in your library using the metadata editor in the server dashboard. There are a few tutorials in the KB that will be helpful. Some of the artwork in the tutorials will be out of date (we're working on it) but the basic procedures should be good. 1
darengibo 6 Posted July 6, 2014 Author Posted July 6, 2014 Thanks for the quick response! Will check it out..
darengibo 6 Posted July 6, 2014 Author Posted July 6, 2014 PERFECT!! again, THANKS! (sometimes its the simple things!!)
