yeahme4 0 Posted May 2, 2020 Posted May 2, 2020 I am running 1.10.3 on Kodi 19. I am experiencing some issues with resume and watched/unwatched. If I have the Embycon context menu disabled and I open the Kodi context menu, any time I choose "Mark as unwatched", "Mark as watched", or "Reset resume position", they don't work. The context menu disappears but the watched status or resume position stays the same. If I enabled the Embycon context menu, I can toggle watched or unwatched just fine. Also, if I have the Embycon context menu disabled, if I choose to play a movie, it will ask to resume at whatever position or play from beginning. If I choose play from beginning, it still resumes from whatever position it was previously at. I'm assuming it's because auto resume is enabled in Embycon settings, but if I disable that option I get prompted with both Kodi and Embycon asking to resume. If I have auto resume disabled and Embycon context menu enabled, I only get prompted by Embycon menu and it works fine for resuming or starting at the beginning. Are these known issues or do you have any suggestions? Thanks.
TeamB 2440 Posted May 2, 2020 Posted May 2, 2020 These are known limitations of kodi. That is the reason for the EmbyCon context menu, it knows how to interact with the dynamic items generated by the add-on, the built in context menu does not.
