mchammer 3 Posted May 24, 2020 Posted May 24, 2020 The channels without epg data will not be enabled by default. You will need to add epg data to those channels.
Luke 42244 Posted May 24, 2020 Posted May 24, 2020 The channels without epg data will not be enabled by default. You will need to add epg data to those channels. You can play channels without guide data, it's just that the EPG will be empty.
alexjcgdf 0 Posted May 24, 2020 Author Posted May 24, 2020 You can play channels without guide data, it's just that the EPG will be empty.You are right @@Luke , and that was the reason I tried xTeVe , to see if I could put the TV guide and the groups that comes as default with my IPTV provider. Think I will have to wait for a newer version of Emby in the future that have those features embedded. Is there an ETC or something for this feature? Not pushing here, just asking. Enviado de meu Pixel 3 XL usando o Tapatalk
