WonkoTheSane 13 Posted May 2, 2020 Posted May 2, 2020 Hi all, Emby seems to have trouble resuming HEVC files when the content is being transcoded. When I'm trying to resume such a video in Firefox, Emby gets stuck on the spinning circle indefinetly -> transcoding. Resuming the same video at the same position on my Shield TV works without a problem -> direct play. Logs attached to this post. Best regards Matthias emby-logs.zip
Luke 42246 Posted May 3, 2020 Posted May 3, 2020 Hi, as a test, would you mind trying a Chromium based browser such as Chrome or Opera to compare? thanks.
WonkoTheSane 13 Posted May 3, 2020 Author Posted May 3, 2020 (edited) Sure, Luke. Logs attached. Thanks! emby-logs.zip Edited May 3, 2020 by WonkoTheSane
bkrn 1 Posted May 3, 2020 Posted May 3, 2020 (edited) I experienced the same problem when hardware transcoding x265. Last I tested this problem occured with multiple mkv files merged with MKVToolNix without errors. Edited May 3, 2020 by bkrn
bkrn 1 Posted May 3, 2020 Posted May 3, 2020 (edited) Alright, decided to reproduce the setup (docker). Found out it doesn't happen with all x265 videos. On the videos it does it's inconsistent. On the video for American Beauty it resumed the video (to my surprise), but when I tried the exact same again later it didn't.... Though the 21 Jump Street resumed fine after doing the same a few times American Beauty: Apocalypse Now: Jump Street: The World is Not Enough: I hope this whole thing doesn't reveal personal info... americanbeauty.tar.gz apocalypsenow.tar.gz jumpstreet.tar.gz theworldisnotenough.tar.gz AmericanBeauty_MediaInfo.txt ApocalypseNow_MediaInfo.txt JumpStreet_MediaInfo.txt TheWorldIsNotEnough_MediaInfo.txt Edited May 3, 2020 by bkrn
bkrn 1 Posted May 4, 2020 Posted May 4, 2020 Update: android mobile app resumes videos without problems (with transcoding). When I force x265 encoding with the EmbyCon kodi addon it loads (loading circle, no video) and after a while gives me an error: "One or more items failed to play. Check the log for more information about this message". When direct playing with EmbyCon it resumes just fine.
Luke 42246 Posted May 16, 2020 Posted May 16, 2020 As a test, if you disable hardware transcoding in server transcoding settings, does this have any impact?
WonkoTheSane 13 Posted May 20, 2020 Author Posted May 20, 2020 I just did a quick test with a single file. For me, it didn't make a difference.
bkrn 1 Posted May 20, 2020 Posted May 20, 2020 It's been a while, but I'm pretty sure when I removed the audio from the mkv container, the video resumed without problems.When I remuxed it with the 21 jump street video I think the same problem occured (not 100% on this, I'll try this again within the next few days). This suggests the audio file must be at fault...
WonkoTheSane 13 Posted May 22, 2020 Author Posted May 22, 2020 It's been a while, but I'm pretty sure when I removed the audio from the mkv container, the video resumed without problems.When I remuxed it with the 21 jump street video I think the same problem occured (not 100% on this, I'll try this again within the next few days). This suggests the audio file must be at fault... I have a bit of free time on my hands, so tried this (removing the audio track). Made no difference for me.
Luke 42246 Posted July 6, 2020 Posted July 6, 2020 @WonkoTheSane are you still having an issue with this?
bkrn 1 Posted July 21, 2020 Posted July 21, 2020 Just tested on the latest beta and the video does now resume (4.5.0.14-beta). The problem does still occur on the stable release. Is there an ETA for a stable release update?
Luke 42246 Posted July 27, 2020 Posted July 27, 2020 Not yet but hopefully soon. Thanks for the feedback.
