gregkodi 4 Posted May 2, 2020 Posted May 2, 2020 (edited) Edit: It works when i turn Emby on my TV, but for some reason it does not work when i want to use emby on my laptop. Any ideas? Hello all, i have tried to use liveTV, and it does not play any channels. I used this feature in the past (3-4 months ago). Back then everything was working just fine. I even configured emby to record a movie to disk, which was amazing. I tried to play a channel today and there is just circle spinning, thats all. I tried using web browser/chrome, then i used on my windows emby premier , also same thing. Is there anything someone can help me with ? LEt me know if i can add some logs. Not sure which one to check. I clicked somewhere , and found some log : I also tried to give the playlist url with additional : ?type=m3u_plus&output=m3u8 at the end , but this has changed nothing and i still can't play anything . In the TV / VLC i tried to open it, and everything there is working just fine. Any idea if something has changed in Emby , or if there is some current bug that does not allow to use liveTV? log part:: 2020-05-02 13:14:11.428 Info HttpServer: HTTP Response 500 to 192.168.1.129. Time: 42ms. http://192.168.1.243:8096/emby/Items/150857/Images/Primary?maxWidth=800&tag=5ca3f34083c41911a63d7b8cd4362511&quality=90 2020-05-02 13:14:17.408 Info HttpServer: HTTP POST http://192.168.1.243:8096/emby/Items/150857/PlaybackInfo?UserId=87aff48ad4d14793892c8128c7421711&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&MaxStreamingBitrate=140000000&DirectPlayProtocols=File%2CHttp%2CRtp%2CRtmp%2CRtsp%2CFtp. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) EmbyTheater/3.0.11 Chrome/80.0.3987.137 Electron/8.1.0 Safari/537.36 2020-05-02 13:14:17.412 Info MediaInfoService: User policy for embysvr. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2020-05-02 13:14:17.412 Info LiveTvManager: Opening channel stream from Emby, external channel Id: m3u_93754bc1078e613f9a156a774546b4ca7ecd3d95075542590379fae4067bc0fe 2020-05-02 13:14:17.412 Info LiveTV: Streaming Channel m3u_93754bc1078e613f9a156a774546b4ca7ecd3d95075542590379fae4067bc0fe 2020-05-02 13:14:17.414 Error M3UTunerHost: Error opening tuner *** Error Report *** Version: 4.4.2.0 Command line: /var/packages/EmbyServer/target/server/EmbyServer.exe -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -ffdetect /var/packages/EmbyServer/target/ffmpeg/bin/ffdetect -restartexitcode 121 Operating system: Unix 4.4.59.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 6.8.0.105 (tarball Sun Apr 5 17:28:17 UTC 2020) Runtime: file:///volume1/@appstore/EmbyServer/3rdparty/mono/6.8.0.105/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/4.4.2.0 MediaBrowser.Controller.LiveTv.LiveTvConflictException: MediaBrowser.Controller.LiveTv.LiveTvConflictException: M3U simultaneous stream limit has been reached. at Emby.LiveTV.TunerHosts.M3UTunerHost.GetChannelStream (MediaBrowser.Model.LiveTv.TunerHostInfo info, MediaBrowser.Controller.LiveTv.ChannelInfo channelInfo, System.String streamId, System.Collections.Generic.List`1[T] currentLiveStreams, System.Threading.CancellationToken cancellationToken) [0x0006c] in <1743a3fa6a05425fb8edd25936ba9bd0>:0 at Emby.LiveTV.TunerHosts.BaseTunerHost.GetChannelStream (System.String channelId, System.String streamId, System.Collections.Generic.List`1[T] currentLiveStreams, System.Threading.CancellationToken cancellationToken) [0x00286] in <1743a3fa6a05425fb8edd25936ba9bd0>:0 Source: mscorlib TargetSite: Void Throw() 2020-05-02 13:14:17.420 Error HttpServer: Error processing request *** Error Report *** Version: 4.4.2.0 Command line: /var/packages/EmbyServer/target/server/EmbyServer.exe -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -ffdetect /var/packages/EmbyServer/target/ffmpeg/bin/ffdetect -restartexitcode 121 Operating system: Unix 4.4.59.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 6.8.0.105 (tarball Sun Apr 5 17:28:17 UTC 2020) Runtime: file:///volume1/@appstore/EmbyServer/3rdparty/mono/6.8.0.105/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/4.4.2.0 MediaBrowser.Controller.LiveTv.LiveTvConflictException: MediaBrowser.Controller.LiveTv.LiveTvConflictException: Exception of type 'MediaBrowser.Controller.LiveTv.LiveTvConflictException' was thrown. at Emby.LiveTV.TunerHosts.BaseTunerHost.GetChannelStream (System.String channelId, System.String streamId, System.Collections.Generic.List`1[T] currentLiveStreams, System.Threading.CancellationToken cancellationToken) [0x003ad] in <1743a3fa6a05425fb8edd25936ba9bd0>:0 at Emby.LiveTV.EmbyTV.GetChannelStreamWithDirectStreamProvider (System.String channelId, System.String streamId, System.Threading.CancellationToken cancellationToken) [0x0020c] in <1743a3fa6a05425fb8edd25936ba9bd0>:0 at Emby.LiveTV.LiveTvManager.GetChannelStream (System.String id, System.String mediaSourceId, System.Threading.CancellationToken cancellationToken) [0x00145] in <1743a3fa6a05425fb8edd25936ba9bd0>:0 at Emby.LiveTV.LiveTvMediaSourceProvider.OpenMediaSource (System.String openToken, System.Threading.CancellationToken cancellationToken) [0x000a5] in <1743a3fa6a05425fb8edd25936ba9bd0>:0 at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal (MediaBrowser.Model.MediaInfo.LiveStreamRequest request, System.Threading.CancellationToken cancellationToken) [0x000b4] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStream (MediaBrowser.Model.MediaInfo.LiveStreamRequest request, System.Threading.CancellationToken cancellationToken) [0x00078] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.MediaEncoding.Api.MediaInfoService.OpenMediaSource (Emby.Server.MediaEncoding.Api.OpenMediaSource request) [0x00099] in <4fd6833b4dd04ffc9f49bdc58c621fe4>:0 at Emby.Server.MediaEncoding.Api.MediaInfoService.GetPlaybackInfo (Emby.Server.MediaEncoding.Api.GetPostedPlaybackInfo request, System.Threading.CancellationToken cancellationToken) [0x0087b] in <4fd6833b4dd04ffc9f49bdc58c621fe4>:0 at Emby.Server.MediaEncoding.Api.MediaInfoService.Post (Emby.Server.MediaEncoding.Api.GetPostedPlaybackInfo request) [0x0007d] in <4fd6833b4dd04ffc9f49bdc58c621fe4>:0 at Emby.Server.Implementations.Services.ServiceController.GetTaskResult (System.Threading.Tasks.Task task) [0x00081] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync (Emby.Server.Implementations.HttpServer.HttpListenerHost appHost, MediaBrowser.Model.Services.IRequest httpReq, MediaBrowser.Model.Services.IResponse httpRes, Emby.Server.Implementations.Services.RestPath restPath, System.String responseContentType, System.Threading.CancellationToken cancellationToken) [0x001da] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler (MediaBrowser.Model.Services.IRequest httpReq, System.ReadOnlyMemory`1[T] urlString, System.ReadOnlyMemory`1[T] localPath, System.Threading.CancellationToken cancellationToken) [0x00b52] in <3605319732a64e8282cfdf09a091f02e>:0 Source: mscorlib TargetSite: Void Throw() ?type=m3u_plus&output=m3u8 I have removed iptv sources/epg. I have rebooted emby, i have added again, still not working :/ i have no idea why is this happening. Edited May 2, 2020 by gregkodi
mastrmind11 722 Posted May 2, 2020 Posted May 2, 2020 right there in the log: M3U simultaneous stream limit has been reached.
gregkodi 4 Posted May 2, 2020 Author Posted May 2, 2020 (edited) But how can limit be reached, if there is nobody else watching it but me ? the stream limit is set to 1, im the only one using emby. Am i supposed to use limit 2 ? I just switched it to 2, same thing. It works on my TV emby app . I dont understand why this does not work when i use it on PC chrome, web browser? Edited May 2, 2020 by gregkodi
Luke 42243 Posted May 3, 2020 Posted May 3, 2020 Hi there, can you please attach the complete emby server log? thanks.
gregkodi 4 Posted June 13, 2020 Author Posted June 13, 2020 On 5/3/2020 at 8:45 AM, Luke said: Hi there, can you please attach the complete emby server log? thanks. Hello Luke, i am sorry for the delay. embyserver.txtffmpeg-remux-c2ea0771-b4b4-45e4-b01b-f8ee191729f6_1.txt In case i attached wrong log files, can you let me know which one should i obtain ?
gregkodi 4 Posted June 13, 2020 Author Posted June 13, 2020 I have also checked with stream limit to 0 , its the same thing while opening in web browser.
Luke 42243 Posted June 28, 2020 Posted June 28, 2020 On 6/13/2020 at 1:30 PM, gregkodi said: Hello Luke, i am sorry for the delay. embyserver.txtffmpeg-remux-c2ea0771-b4b4-45e4-b01b-f8ee191729f6_1.txt In case i attached wrong log files, can you let me know which one should i obtain ? @gregkodi everything looks normal in this log example. Are you sure this is the right one? Would you mind providing a new example? Thanks !
gregkodi 4 Posted May 30, 2021 Author Posted May 30, 2021 On 7/20/2020 at 10:31 PM, Luke said: @gregkodi ? Hello, really sorry for the 'delay'. I just wanted to report that this is working now fine. I was not using the emby live tv, for some time, and just moved to new synology, and i gave it a try, so not sure, if this got fixed in some new release, BUT... I have no issues with playing live tv, inside the TV using emby, or inside laptop with windows and browser. All is working fine.
