TeamB 2440 Posted February 20, 2023 Author Posted February 20, 2023 1 hour ago, xiaobaiya said: Hello, I have been using playback_reporting for over a year and am a loyal user from China. However, I have been troubled by an issue regarding time zones. I installed EMBY on Docker, and even though I have set the parameter to TZ=CST-8 or TIMEZONE or TZ=Asia/Shanghai, I am still unable to set the time zone. The time displayed on the summary page is always 8 hours behind China time, for example, if my viewing record at 16:00, it shows as 8:00 in the summary. However, the time displayed on the Activity page provided by EMBY is correct. Can you please let me know if there is an issue with my settings or if the plugin is not detecting the time zone? If you run a query on the query tab is the raw date/time returned in the results correct?
xiaobaiya 6 Posted February 20, 2023 Posted February 20, 2023 1 hour ago, TeamB said: If you run a query on the query tab is the raw date/time returned in the results correct? Still wrong
TeamB 2440 Posted February 20, 2023 Author Posted February 20, 2023 11 hours ago, xiaobaiya said: Still wrong ok thank you for the report, i will look into it.
DarWun 357 Posted February 20, 2023 Posted February 20, 2023 (edited) @TeamBMinor thing that I've been intending on reporting for a while now. From the Breakdown screen you can click on an item to take you to the "User Playback Summary" for that item. In most cases, an "*" will be appended to the search query so that only playback events for that item are shown. However, if there is a special character in the title name, such as an "&", the "*" won't get appended to the search query and no items show up. Clicking on Lockwood & Co. results in the following search query: And no items show up without manually adding "*". Edited February 20, 2023 by DarWun 1
TeamB 2440 Posted February 20, 2023 Author Posted February 20, 2023 22 minutes ago, DarWun said: @TeamBMinor thing that I've been intending on reporting for a while now. From the Breakdown screen you can click on an item to take you to the "User Playback Summary" for that item. In most cases, an "*" will be appended to the search query so that only playback events for that item are shown. However, if there is a special character in the title name, such as an "&", the "*" won't get appended to the search query and no items show up. Clicking on Lockwood & Co. results in the following search query: And no items show up without manually adding "*". Thanks for reporting, I will look into it 1
TeamB 2440 Posted February 21, 2023 Author Posted February 21, 2023 19 hours ago, xiaobaiya said: Hello, I have been using playback_reporting for over a year and am a loyal user from China. However, I have been troubled by an issue regarding time zones. I installed EMBY on Docker, and even though I have set the parameter to TZ=CST-8 or TIMEZONE or TZ=Asia/Shanghai, I am still unable to set the time zone. The time displayed on the summary page is always 8 hours behind China time, for example, if my viewing record at 16:00, it shows as 8:00 in the summary. However, the time displayed on the Activity page provided by EMBY is correct. Can you please let me know if there is an issue with my settings or if the plugin is not detecting the time zone? I think this is an issue with setting your time zone in docker when logging it tries to use your local time zone and from what I see it is using GMT not yor correct time zone I dont think I can fix this in the plugin unless I do something like treat all time as GMT until display time but even then if your time zone is not set correctly it will still give you a weird offset. I do not know how or why emby is able to show you correct times in the activity page, could be based on browser TZ
TeamB 2440 Posted February 21, 2023 Author Posted February 21, 2023 latest version - 2.0.0.1 - fix url encoding on summary page - add user and min duration ignore to notification events 2
xiaobaiya 6 Posted February 21, 2023 Posted February 21, 2023 8 hours ago, TeamB said: I think this is an issue with setting your time zone in docker when logging it tries to use your local time zone and from what I see it is using GMT not yor correct time zone I dont think I can fix this in the plugin unless I do something like treat all time as GMT until display time but even then if your time zone is not set correctly it will still give you a weird offset. I do not know how or why emby is able to show you correct times in the activity page, could be based on browser TZ Thank you for the reminder. It was indeed the time adjusted by the browser. I checked the embyserver.txt file and found that it was also incorrect. I had thought it was a problem with the plugin, but after several investigations, I found that TZ=Asia/Shanghai is effective. Maybe I typed extra letters or spaces before.ahh In addition, I really enjoy using this plugin. I can provide Chinese translation support for the plugin and hope that there will be localization features in the future. 1
TeamB 2440 Posted February 21, 2023 Author Posted February 21, 2023 16 minutes ago, xiaobaiya said: I can provide Chinese translation support for the plugin and hope that there will be localization features in the future. I have not looked into localization of plugins, perhaps it is something that can be done, I will investigate when I get time.
DarWun 357 Posted February 21, 2023 Posted February 21, 2023 22 hours ago, TeamB said: Thanks for reporting, I will look into it @TeamBAnd look into it you did. Issue resolved with 2.0.0.1. Thanks!!!
HaraldBluetooth 22 Posted February 22, 2023 Posted February 22, 2023 Hi, many thanks for this plugin, it's really useful. Would it be possible to make a report/query of how many hours real activity (browsing/playing/scheduled tasks etc.) there has been on the server (sum per day/week/month/year). So how many hours has the server been busy with anything.
TeamB 2440 Posted February 22, 2023 Author Posted February 22, 2023 (edited) 1 hour ago, HaraldBluetooth said: Hi, many thanks for this plugin, it's really useful. Would it be possible to make a report/query of how many hours real activity (browsing/playing/scheduled tasks etc.) there has been on the server (sum per day/week/month/year). So how many hours has the server been busy with anything. monitoring general browsing and system stats are beyond the scope of this plugin. there are a few ways of getting this info, you can analyse the emby server logs to give you general usage stats, you can use a general log tool to do this and it will give you browsing stats etc. the following thread shows an example of analysing logs when using a reverse proxy https://emby.media/community/index.php?/topic/54690-how-to-integrate-google-analytics-code/ for the server hardware what you are after here is server load, cpu, ram, disk io etc, there are a bunch of tools for this also. Edited February 22, 2023 by TeamB
HaraldBluetooth 22 Posted February 22, 2023 Posted February 22, 2023 14 minutes ago, TeamB said: monitoring general browsing and system stats are beyond the scope of this plugin. there are a few ways of getting this info, you can analyse the emby server logs to give you general usage stats, you can use a general log tool to do this and it will give you browsing stats etc. for the server hardware what you are after here is server load, cpu, ram, disk io etc, there are a bunch of tools for this also. Thanks for your answer TeamB.
LeshaShklar 5 Posted March 15, 2023 Posted March 15, 2023 plugin doesnt create music playback statistics?
TeamB 2440 Posted March 15, 2023 Author Posted March 15, 2023 4 hours ago, LeshaShklar said: plugin doesnt create music playback statistics? do you mean on the breakdown tab?
LeshaShklar 5 Posted March 16, 2023 Posted March 16, 2023 8 hours ago, TeamB said: do you mean on the breakdown tab? Yes ) and it seems to me that the plugin does not consider listening to music anywhere playback tab, breakdown tab, time tab
seanbuff 1357 Posted March 16, 2023 Posted March 16, 2023 18 minutes ago, LeshaShklar said: Yes ) and it seems to me that the plugin does not consider listening to music anywhere playback tab, breakdown tab, time tab Hmmm not true, all my music activity shows up in all those tabs as type "Audio" -- appears to be working fine here 1
Happy2Play 9814 Posted March 16, 2023 Posted March 16, 2023 30 minutes ago, LeshaShklar said: Yes ) and it seems to me that the plugin does not consider listening to music anywhere playback tab, breakdown tab, time tab Yes I see Audio on Playback, Summary and Breakdown just show total audio number of tracks played and Audio total time played. Playback and Summary Breakdown type
LeshaShklar 5 Posted March 16, 2023 Posted March 16, 2023 15 minutes ago, seanbuff said: Hmmm not true, all my music activity shows up in all those tabs as type "Audio" -- appears to be working fine here oh... true my mistake, I chose the wrong user... 1
LeshaShklar 5 Posted March 16, 2023 Posted March 16, 2023 but i think i found a bug if you don't change anything, it works fine but if you change something - user, date, checkbox then formatting breaks 2
Happy2Play 9814 Posted March 16, 2023 Posted March 16, 2023 13 minutes ago, LeshaShklar said: but i think i found a bug if you don't change anything, it works fine but if you change something - user, date, checkbox then formatting breaks Yes @TeamBcanvas changes when you change any of the variable for the Time page. { width: 95%; height: 300px; box-sizing: border-box; } to this in my case { width: 1651.25px; height: 1650px; box-sizing: border-box; display: block; } 1
TeamB 2440 Posted March 16, 2023 Author Posted March 16, 2023 4 hours ago, LeshaShklar said: oh... true my mistake, I chose the wrong user... The breakdown page could have albums or songs played, like the tv breakdown, that is the only thing I think is missing.
TeamB 2440 Posted March 16, 2023 Author Posted March 16, 2023 4 hours ago, LeshaShklar said: but i think i found a bug if you don't change anything, it works fine but if you change something - user, date, checkbox then formatting breaks yeah, that's a bug, I will look into it.
TeamB 2440 Posted March 17, 2023 Author Posted March 17, 2023 13 hours ago, TeamB said: yeah, that's a bug, I will look into it. this has been fixed now (2.0.0.2) 1 1 2
